Hi :D
I need to spend a 3d model to 2d but with different colors.
Can the soldraw command recognize the different layers and keep their colors?:?
any solution... lisp for example.
greeting from Chile
SolView actually sets the layer names and layer color. I suppose you could write a Lisp routine that would change the color of each unique layer (-DIM, -HID, -VIS and -HAT) enmass.
You cannot have the layers exist in advance or solview/soldraw complains. Therefore I set them up in an las file and import. You have to be sure to follow a standard naming sequence when creating the views.
