StevenNoppe Posted December 16, 2009 Posted December 16, 2009 If I change a block and save it to the hard disk, the blocks already on the drawing do not apply the changes. Is there a command that changes all the blocks in one click? Quote
dbroada Posted December 16, 2009 Posted December 16, 2009 if you make changes to a block in the current drawing (using explode/redefine, refedit or bedit) all graphical changes should be updated immediately but any attribute changes need an ATTSYNC to get them to update. If you have changed a block and want it updated in anotehr drawing you must reinsert it from the modified file and again ATTSYNC if it has attributes. I don't know of any one click solutions. Quote
NBC Posted December 16, 2009 Posted December 16, 2009 Don't think there is an easy way using LT either Quote
StevenNoppe Posted December 16, 2009 Author Posted December 16, 2009 if you make changes to a block in the current drawing (using explode/redefine, refedit or bedit) all graphical changes should be updated immediately but any attribute changes need an ATTSYNC to get them to update. If you have changed a block and want it updated in anotehr drawing you must reinsert it from the modified file and again ATTSYNC if it has attributes. I don't know of any one click solutions. Well, I use block edit to change the position of a text. Then I save the block and exit block edit, but the blocks in my current drawing do not change? If I reinsert the block, then the text has changed position. Quote
Tommy78 Posted December 16, 2009 Posted December 16, 2009 Have you tried BATTMAN? BATTMAN > select text to update > click sync The text positions should stay the same Quote
StevenNoppe Posted December 16, 2009 Author Posted December 16, 2009 That worked! I typed battman, then chose the block with the text and then I pressed the "sync" button After that all the text from the other blocks jumped to the correct position! thx Quote
dbroada Posted December 16, 2009 Posted December 16, 2009 I missed your version. ATTSYNC is a recent addition and not available on 2000i or LT. I didn't realise that BATTMAN was available that far back either. Something else must have happened along the way but I missed it. On my current version of AuotCAD ( 2008 ), text IS moved when you update a block but attributes aren't. Quote
StevenNoppe Posted December 16, 2009 Author Posted December 16, 2009 no problem Dave by the way I now have Autocad 2008 LT. I will change my profile immediatly Quote
