Many thanks Alan,
I shall implement those changes momentarily :)
No problem. I hadn't given this a look and I thought I'd give it a go.
  • Replies 90
  • Lee Mac
    40
  • alanjt
    10
  • asos2000
    9
  • DVDM
    4
Posted Images
I'm glad you like it :)
I was converting some text objects from a file (provided by client) and it made me think of your routine.
I have updated the first post to Version 1.8, this should hopefully fix the UCS errors and text rotation issues.
Thanks,
Lee
LEE
First thanks for this routine
- Can I control the distance between lines?
- Does the lisp keep the text angle?
- Mtext not moving with mouse when change UCS
The lisp rotate the text to 0 angle
I believe this is controlled using: TSPACEFAC
It will keep the angle of the first text selected.
The latest version should fix all UCS issues, what is your UCS set to?
Thanks LEE
I was using V-1.7
Could one of these lines has the version
ّ¤؛°`°؛¤ّ  Text2MText.lsp ~ Copyright © by Lee McDonnell  ّ¤؛°`°؛¤ّ
  ~¤~             ...Type "T2M" to Invoke...                ~¤~   nil
The filename has the version - I wanted to keep all my programs consistent.
Its funny that the characters look different on your system :)
whats the characters looks on your system?
Language package differences.
Oh, it could also be that I might have changed my command line font...
Possibly (that looks like the standard one though).
Hi Lee - I really like this, and I can see myself using it in preference to the Express Tools version. The only thing I prefer about the Express Tools version though is the ability to select text with a crossing box rather than picking each bit of text exactly. This also allows you to select more than one bit of text at a time. Does that make sense?
Hi Rooster - I'll try to incorporate something similar in a later version - it might take a bit of work though... :geek:
Fantastic! I will look forward to that :)
Try the updated code - its not perfect, but its the best I could do for the minute :) SelectionSet isn't available until after the first pick.
  • 2 weeks later...
thanks as ever, lee - this will come in really handy
