Hi, I'm new here and I'm also very new to AutoCAD. Here's my question:
How can you make a tapered cylinder? I need specific radii on both ends, with a specific height. Thanks!
Sounds like a sheetmetal layout(?).
Welcome to the forums jaypooner, where are you posting from?
Try looking through the library at http://www.thesheetmetalshop.com/module-htmlpages-display-pid-198.html.
I'm sure more forum members will be logging on if they aren't shoveling the heavy, wet, white "stuff" (blizzard goin' on East Coast, USA).
Plan view looks like two [2] circles.
Elevation, two horizontal lines, two vertical lines.
Looks like a trapezoid.
Command: CONE
Specify center point of base or [3P/2P/Ttr/Elliptical]:
Specify base radius or [Diameter] : (Specify Base Radius)
Specify height or [2Point/Axis endpoint/Top radius] : T
Specify top radius : (Specify Top Radius)
Specify height or [2Point/Axis endpoint] : (Specify Height)
Revolve or extrude with taper are other possible solutions. If sheet metal you might want to revolve a single line as surface and then Thicken. If you want flat pattern you might investigate Autodesk Inventor.
Students can download Inventor for free from http://www.autodesk.com/edcommunity
Tank: california. and no its a solid 3d cylinder
Cad: i'm not proficient enough to use code yet!
JD: extrude with taper? ill look into that. revolve sounds plausible as well
:lol: Code? :?
It's a command line sequence.
Type CONE at the command line and follow the prompts.
LOFT and SHELL might be a good way of creating this.
