OLE (Excel) Failed to launch server app....)
Ok so a book fell onto my keyboard, causing a series of commands to take place...now whenever i attempt to open an OLE object- in this case, and Excel worksheet- i get This error: Failed to launch server application.
moz-screenshot.jpgNo numbers to search no other approach works. whether i double click or go through shortcut menu or pulldowns nothing will work- same error.
There must be a setting somewhere in CAD that allows me to set this stuff up but i just dont know where.
ple:shock:ase help!
Saw this suggestion at the AutoDesk Discussions Forum. No promises made.
To update OLE links:
  1. Type olelinks on the command line and press ENTER, or from the Edit menu, choose OLE Links.
  2. In the Links dialog box, select the link you want to update from the list of all linked objects and their addresses.
  3. Choose the Update Now button.
tried that, the olelinks seems to be disabled...i get nothing happening.
Is there a way to enable?
