yeti Posted December 23, 2009 Posted December 23, 2009 Hello all, This is my first post, and essentially my first go at 3D in AutoCAD. I was given a model of several mound shapes, 3 of which are 3D solids, but the fourth is a collection of triangular regions. The mound is a semi-organic shape, not a simple rectilinear box or something that I can EXTRUDE to where I want it. I am looking for a way to unify all the region facets together as a 3D solid so that I can slice them into smaller chunks for our production drawings. So far, I have been able to CONVTOSURFACE them into one big surface, but cannot CONVTOSOLID from there. I can convert it to a mesh, but still cannot convert that into a solid for slicing. I have seen mention of the m2s.lsp lisp routine, but that seems to make a thin skin (something like extruding each facet) What can I do? Please, O all-knowing CAD gurus, you are my only hope! Sincerely, At Wit's End Quote
JD Mather Posted December 23, 2009 Posted December 23, 2009 So far, I have been able to CONVTOSURFACE them into one big surface Sounds like Slice with Surface option or maybe Thicken. Can you attach the surface here? Quote
yeti Posted December 23, 2009 Author Posted December 23, 2009 I would like to attach the file, but I cannot get it below the 250KB file size limit. The smallest I can get it to is 353KB... Arrgh! Quote
ReMark Posted December 23, 2009 Posted December 23, 2009 Can the file be broken up in some manner? Quote
yeti Posted December 23, 2009 Author Posted December 23, 2009 I don't think so... it's one "mound" made up of about 660 pieces. I suppose I could chop it up into multiple files, but that's more work for anyone else to put it back together again to look at it. /sigh Quote
CarlB Posted December 23, 2009 Posted December 23, 2009 Don't know if the "face to solid" lisp will do any better than the "mesh to solid" -if you do have 3d faces... www.accustudio.com/data/marketplace/free/F2S.lsp Quote
JD Mather Posted December 23, 2009 Posted December 23, 2009 I would like to attach the file, but I cannot get it below the 250KB file size limit. The smallest I can get it to is 353KB... Shademode 2d File Save As (make sure you do Save As) Go to Windows Explorer Right click on the filename and select Send to Compressed (zipped) Folder What is the size of the resulting *.zip file? Quote
yeti Posted December 23, 2009 Author Posted December 23, 2009 Thanks JD, I'm so spun about this that I completely forgot about zipping. Or, rather, I didn't think a .zip would garner that much space! I'm attaching the 245KB .zip for the individual regions version of the model. Thanks again for your help! sc9 mound4b.zip Quote
JD Mather Posted December 23, 2009 Posted December 23, 2009 What is your definition of "several"? I was able to get the repaired model to a solid, but there were "several" missing surfaces. The solid ended up being over 1Meg zipped, too large to attach here. Quote
yeti Posted December 23, 2009 Author Posted December 23, 2009 My apologies! The "several" I mentioned in my first post was in relation the the number of mounds in the scene I am working on. The mound I attached has 660 facets. In other versions of the mound (water-tight surfaces where I had filled in the missing bits) the drawing ended up being around 1.3MB as well. In order to get the drawing to you I had to use the simplest version I had: the 660 regions. Might you be able to tell me how you got to where you did, in lieu of an attached file? Again, my apologies, and my thanks! Quote
JD Mather Posted December 23, 2009 Posted December 23, 2009 Might you be able to tell me how you got to where you did, in lieu of an attached file? Well, I used a modern 3D CAD program, not AutoCAD - so it looks like I won't be of much help since I can't attach the results here. Quote
yeti Posted December 23, 2009 Author Posted December 23, 2009 Ah, more's the pity. Thanks for your help. Hopefully someone with a woefully dated CAD program (like AutoCAD 2010) can give me some pointers. Quote
ReMark Posted December 24, 2009 Posted December 24, 2009 yeti: Do you know anyone who is using Inventor? You're not a student by any chance are you? Quote
