sleezemcfly Posted December 24, 2009 Posted December 24, 2009 Oi, I'm trying to changed the transparency of 3d solids in my model, but by viewport. Because of my **** computer, i really dont want to create multiple models and render different materials just so that the can be transparent in my layouts. I guess to be more specific, I had a 3d solid model, and in my layouts i want different objects to be transparent, while some retain their non transparency. Any help? Logan Quote
ReMark Posted December 24, 2009 Posted December 24, 2009 And what program will you be attempting to do this in? Sounds like something better suited to 3ds Max. Quote
sleezemcfly Posted December 24, 2009 Author Posted December 24, 2009 Civil 3D 2009, haha its all I've got Quote
sleezemcfly Posted December 24, 2009 Author Posted December 24, 2009 And if it helps, I have each object as its own layer, so possibly changing layer transparency in each viewport, in each layout? Quote
ReMark Posted December 24, 2009 Posted December 24, 2009 I am not aware of any ability to change transparency via viewport. Quote
mrbucket Posted December 24, 2009 Posted December 24, 2009 Viewports can have different properties for views and visual styles. Is that what you mean? Drawing2 LETTER-L (1).pdf Quote
sleezemcfly Posted December 28, 2009 Author Posted December 28, 2009 No, I know the visual styles can vary by viewport, I want the visual style to remain realistic, I just want certain members to look transparent in separate viewports while some remain non-transparent. Quote
ReMark Posted December 28, 2009 Posted December 28, 2009 I do not believe this is possible without a lot of work most of which would involve duplicating objects and materials and tweaking the latter. Example: Stainless steel material (normal) and stainless steel material (semi-transparent). See what I'm getting at? Quote
