salman Posted December 25, 2009 Posted December 25, 2009 I want to find the definition of a line type loaded in a drawing. I have checked all the .lin files in the following path C:\Documents and Settings\USER\Application Data\Autodesk\AutoCAD 2007\R17.0\enu\support but not able to find the definition of that line type. Where can I find that definition. Quote
lpseifert Posted December 25, 2009 Posted December 25, 2009 If, for example, the dwg came from an outside source the linetype definition is embedded in the dwg. Look here for a routine to extract the definition. http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3958 Quote
dbroada Posted December 26, 2009 Posted December 26, 2009 as an aside, how do you embed the definition into a file? I have a number of "special" lines and I make sure the file is in a network folder but some engineers refuse to follow instructions - can I embed it somehow? Quote
lpseifert Posted December 26, 2009 Posted December 26, 2009 Just by loading the linetype the definition is "embedded". When you open a dwg, it isn't necessary for the dwg to 'find' a .lin file; the loaded linetypes' definitions are part of the dwg. Of course if the linetype definition has shapes, it needs to have access to the appropriate .shx file. Quote
dbroada Posted December 27, 2009 Posted December 27, 2009 yes sorry, my definitions do use shape files (which I have pathed). Is there a way to embed shapes? Quote
lpseifert Posted December 27, 2009 Posted December 27, 2009 I believe if shapes are used, the shx file must be accessible (i.e. in the support path or hard coded paths). Quote
toberino Posted September 10, 2010 Posted September 10, 2010 If, for example, the dwg came from an outside source the linetype definition is embedded in the dwg. Look here for a routine to extract the definition.http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3958 Thanks lp!!!! Quote
fuccaro Posted September 11, 2010 Posted September 11, 2010 Dbroada For sure this is not new for you, just for the benefit of others: if you send out a drawing, use ETRANSMIT and AutoCAD will pack together everything the drawing needs. Quote
dbroada Posted September 11, 2010 Posted September 11, 2010 DbroadaFor sure this is not new for you, just for the benefit of others: if you send out a drawing, use ETRANSMIT and AutoCAD will pack together everything the drawing needs. but I will point out that (at least in 2006) fonts ARE NOT sent by default when using ETRANSMIT. Remeber to check the options! Quote
