Creating a hole in a surface with no thickness?
I apologize if this question is simple, but for some reason I cannot get this to work...
I have drawn a 3d steel "c" channel, however, there is no thickness. I plan to export it into ABAQUS in which then the thickness will be applied. I want to just add holes in the web of the "c" channel, however, I cannot use to the hole feature since it is technically not a solid. I have tried multiple things such as extruding the holes and then deleting the faces, however, for some reason i cannot delete the hole face in which the hole lies.
Thank You,
sketch circle, exit sketch mode
Trim Surface
If you can't figure it out zip and attach your file here.
