Rojek Posted January 3, 2010 Posted January 3, 2010 What I wonna do is to pick a polyline on screen then fillet it's edges and add it to block. I find out how to fillet edges but I don't know how to add it to block with fillet edges:/ Public Sub bar() 'Checking for existing blocks Dim objBlock As AcadBlock Dim strBlockList As String Dim n As Integer n = -3 strBlockList = "List of blocks: " For Each objBlock In ThisDrawing.Blocks n = n + 1 strBlockList = strBlockList & vbCr & objBlock.Name Next MsgBox strBlockList ' MsgBox n '**********copied from [url="http://www.cadtutor.net/forum/member.php?u=210"]fixo[/url] 'FILLET Dim oPline As AcadLWPolyline Dim varPt As Variant On Error GoTo Error_Trapp ThisDrawing.Utility.GetEntity oPline, varPt, "Select polyline" If Err Then Err.Clear Exit Sub ElseIf Not TypeOf oPline Is AcadLWPolyline Then MsgBox "This is not a LightWeightPolyline" Else Dim filrad As Double filrad = 10 ' CDbl(InputBox(vbCr & vbCr & "Specify fillet radii: ", "Filleting LWPolyline", "10,0")) ThisDrawing.SetVariable "FILLETRAD", filrad Dim commStr As String commStr = "_FILLET _P " & _ "(handent " & Chr(34) & oPline.Handle & Chr(34) & ")" & vbCr ' I have to admit I don't understand this row ThisDrawing.SendCommand commStr End If Error_Trapp: If Err.Number = 13 Then MsgBox "This is not a polyline" & vbCr _ & "Error number: " & Err.Number & vbCr & Err.Description End If '''*********^^^THIS IS NOT MINE. I've copied it form some board and it works 'adding LWPolyline to block Dim Cordinat As Variant Cordinat = oPline.Coordinates Dim indeks As Integer Dim UpperBoundery As Integer Dim LowerBoundery As Integer UpperBoundery = UBound(Cordinat) LowerBoundery = LBound(Cordinat) Do If l > UpperBoundery Then Exit Do End If 'MsgBox Cordinat(l) l = l + 1 Loop Dim objBlockName As String Dim dblOrigin(2) As Double objBlockName = "bar" & n Set objBlock = ThisDrawing.Blocks.Add(varPt, objBlockName) objBlock.AddLightWeightPolyline Cordinat End Sub Quote
cadman2009 Posted January 4, 2010 Posted January 4, 2010 Hi dear Rojek Please go to this link and download your desired tool : http://www.visiblevisual.com/index.php/AutoCad-VB/VBA/database-driven-block-manager.html happy Xmas and have a nice day Quote
