ttsadaf Posted January 4, 2010 Posted January 4, 2010 i want to become a lisp pragrammer......... i want some training tutorials which explain in a very easy method..... can anybody help me......... waitng for your replies......... Quote
viviancarvalho Posted January 4, 2010 Posted January 4, 2010 Best site to start with. http://www.afralisp.net/ Quote
ttsadaf Posted January 4, 2010 Author Posted January 4, 2010 i saw that.......... i need some another site.......... this site has limited things about lisp........ if u suggest me another .......... i vl b thakful to u........... Quote
Fire Alarm Posted January 4, 2010 Posted January 4, 2010 Check out the link below. These were very helpful for me. http://www.cadtutor.net/forum/showthread.php?t=43373&highlight=fire+alarm Quote
Freerefill Posted January 4, 2010 Posted January 4, 2010 I learned a lot from this site: http://www.jefferypsanders.com/autolisp.html Quote
lrm Posted January 4, 2010 Posted January 4, 2010 The best Autolisp book I have found is: Visual Lisp Programming: Principles and Techniques ~ Rod R. Rawls (Author), Mark A. Hagen (Author) The original version was published in 1996 (before Visual LISP). This newer version (2007) is as good. This is a great book if you want to learn the basics and want to use AutoLISP to manipulate geometry. ~Lee Quote
Lee Mac Posted January 4, 2010 Posted January 4, 2010 A few of my links: Starting LISP: http://www.cadtutor.net/forum/showthread.php?t=38760 http://www.cadtutor.net/forum/showthread.php?t=38734 http://www.afralisp.net/ http://www.jefferypsanders.com/autolisptut.html http://ronleigh.info/autolisp/index.htm More Advanced LISP Tutorials: http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-4.html http://www.cs.cmu.edu/afs/cs.cmu.edu/project/ai-repository/ai/html/cltl/clm/node1.html DCL Tutorials: http://www.jefferypsanders.com/autolisp_DCL.html http://www.afralisp.net/ Visual LISP Editor: http://www.afralisp.net/vl/vlisp.htm http://www.afralisp.net/vl/vl-edit.htm http://midpointcad.com/au/docs/lakose_The_Visual_LISP_Developers_Bible.pdf Error Handlers: http://www.afralisp.net/lispa/lisp6.htm http://www.cadtutor.net/forum/showthread.php?t=33966 http://www.cadtutor.net/forum/showpost.php?p=261049&postcount=3 Explanation of the Apostrophe: http://www.cadtutor.net/forum/showpost.php?p=258390&postcount=20 Explanation of Conditionals (CAB/Lee Mac) http://www.cadtutor.net/forum/showpost.php?p=173196&postcount=10 http://www.cadtutor.net/forum/showpost.php?p=240943&postcount=2 http://www.cadtutor.net/forum/showpost.php?p=273108&postcount=12 VL Method Differences: http://www.cadtutor.net/forum/showpost.php?p=258403&postcount=9 PaperSpace/ModelSpace Objects: http://www.cadtutor.net/forum/showpost.php?p=259934&postcount=13 Explanation of a LISP function (Text replacement): http://www.cadtutor.net/forum/showpost.php?p=264546&postcount=15 Localising Variables: http://www.cadtutor.net/forum/showpost.php?p=265649&postcount=4 Car/Cadr/Caddr Explained: http://ronleigh.info/autolisp/afude09.htm http://www.theswamp.org/index.php?topic=31473.0 Default Options http://www.cadtutor.net/forum/showthread.php?t=39634 That should get you started Quote
ttsadaf Posted January 5, 2010 Author Posted January 5, 2010 many many thanx to all of you....... iam going to start with this links.... Quote
