Hi, I'm trying to have my cameras transfered to a fresh file and it seems like it is not supported. I select the cameras->copy to clipboard and then to the fresh file i use paste to original coordinates! Something that would work with a simple object doesn't work with cameras...do i miss something or is it something of that "can't do" autocad issues? (note that i have turned on cameradisplay to 1 in both files) Thank you...
Perhaps a more straight forward approach is in order.
Simply open the drawing with the cameras you want, then perform a "SaveAs" to a new drawing name and delete any unwanted stuff.
Yes, i agree, that would be the way to do it if the only thing that i wanted from my file were the cameras and wanted to end up with a totaly blank file(except the cameras). The thing is that i want to merge two complete drawings in one file. The ground floor and the first floor of a building. Each drawing-file has it's own cameras. Cameras and objects are in their absolute coordinate position so a simple copy from one file and paste to original coordinates to the other, would do the job...But either copying or merging both into a new file, either the one into the other the problem still exists. What do you do in this case? The straight forward approach that you mention is not a solution here. I have come across this problem many times and i ended creating new cameras for at least one file. There is got to be a way. Xref, insert block and everything else i can think of doesn't transfer cameras!!!
Ahh, ok that's a slightly different scenario than what I thought. I'm not aware of a solution to that problem.
Unfortunately, you can't copy cameras. I don't know why, but I've tried a thousand times and it's never worked. I would copy all the properties of the camera(s) and set up a new one in the new drawing and paste the properties in their respective locations.
I can copy and paste cameras in 2010 with no problems. I just can't paste to original coordinates. One thing you might want to try would be to xref file A into file B to use as a placeholder. Then copy and paste the contents of file A into file B, including cameras. Once you have file A pasted into file B, move those file A objects and align them with the file A xref. Once aligned, detach the xref.
Ok...that's the answer! 2010 can copy and paste with no problem except the paste to coordinates thing and the copy with basepoint. Thank you all...
