Hi,
I have Autocad 2002.
I have drawing with 10 Xref's in it and in each Xref I have 50 Attribute blocks. I want to extract 10 Attribute blocks (out of 50) from each Xref. Total I want to extract 100 Attribute blocks out of 500.
Is it possible in Autocad 2002?
Hi,
I have drawing with 10 X-refs in it and in each X-ref I have 50 Attribute blocks. I want to extract 10 Attribute blocks (out of 50) from each X-ref. Total I want to extract 100 Attribute blocks out of 500.
You might be able to use Eattext if 2002 has it.
Have you tried the Attribute Extraction tool?
I have attribute exraction tool, but in this tool I cannot pick few of attribute block from x-ref, I have to extract all the attributes in the x-ref and I need to extract only part of them...
what I want to do is to extract only few attributes out of x-ref in the drawing and with attribute extraction tool (Eattext) I must to extract all the attributes that in the x-ref.
When you are at the stage to select Attributes, you Uncheck All, then you can check which of the Block Attributes you want to extract.
Nudler, I have merged your two threads - please don't start multiple threads about the same question.
My Problem is that In the x-ref I have 100 attribute with the same name and I want to extract only 10 of them.
Erase 90 of them, extract, then Oops
Or extract all of them, and then in a spreadsheet do some editing.
