I've made 2 parallel helix in 3D and I want to hatch it to make spiral stairs or ramp. But, I couldn't hatch it and I couldn't make region and boundary. Can somebodey help me, please? :D:oops:
Don't understand why you would hatch to make stairs or ramp?
Connect the bottoms with a line.
Sweep the line along one of the helixes.
Thicken (for ramp).
well, because I don't know how to do it.
I don't understand how to sweep a line along one spiral...
F1 Sweep
You might go through the tutorials in my signature (written for 2007 Dashboard - but the techniques are the same using the Ribbon interface).
If you can't figure it out attach what you have completed so far.
I made a few errors in logic.
First of all, your outer helix must, of course, be a larger radius than inner helix.
But no matter, you don't need it anyhow - delete it.
You added thickness to your line - that isn't what I said to do.
I said Sweep and then Thicken (the command Thicken F1 - on the surface resulting from the Sweep).
Worked here?
Did you already go through those tutorials I suggested - did you request the sample files?
banovina, 3D.zip
Now I've done it. thank you very much, it looks great :)
you could draw a circle at one end, hatch that and then sweep it along the helix path.
Can you attach a file that demonstrates this technique?
