I get this image about once or twice a day. It causes me to crash.
I need a fix
What are you attempting to do when the error messgae is displayed?
How to fix a runtime error R6025. The recommended procedure is:
"If you have received the message that reads "Runtime error R6025 Pure Virtual Function Call," then the program you are using has been corrupted in some way and will need to be deleted and then re-installed."
Repeated runtime errors of this nature may indicate a problem with the Registry.
You could try using the AutoCAD REPAIR option and see if that works before resorting to uninstalling and reinstalling AutoCAD.
If you do an uninstall/reinstall be advised there is a recommended procedure to follow that is posted at the AutoDesk website.
well im using a 3rd party add on software in cad called Microvellum. It is a software that draws 3D cabinets. It uses 3d solids to create the products. I get it when I try to modify one of the products. On the Microvellum board, they say it is a CAD issue, so that is why Im posting here. It has something to do with MV interacting with CAD.
So there is no issue when you're not using an object created with Microvellum?
Correct. using cad is fine. its only when I use the redraw command in MV (MV has its own redraw command)
You're using a command in one program (MV) that is also present (but may work slightly different) in the other program (AC). Maybe that's the problem? Pop out of MV and then issue the redraw command. What happens?
No, it is compeltly different. this is the actually keyboard entry for the MV redraw "REDRAWPRODUCTV67"
Sounds more like a problem with MV not AC.
Did the command ever work correctly?
yeah, 99 of 100 times it will be fine.
Bad geometry causing the problem?
not that I can think. Because it would crash, then I go back and do the exact same thing and have no issue. I just updated my .NET to 3.5 from 2.0.5. Lets see if that helps.
How did you arrive at the conclusion to update .NET?
did not work, i updated and it still crashed
  • 6 years later...
I am making an addon on AutoCAD and sometimes (not always) I get this report message when the objectModified event is fired.
So I can confirm that it is sure that is your add on.
My $0.05, 2009 is a very old version if your current MV was the version at that time that matched 2009 then probably Ok go to them, if its a 2016 version etc then chances are MV has updated code and linked new libraries, developers are very loath to fix a problem that is 9 versions old. They add new features and old versions just die off.
