Scaling dwg from 1:100 to 1:50 lisp?
Does anybody know if there's an easy way to scale a drawing from 1:100 to 1:50 while the background xref stays the same scale? The basepoint of each blocks/text/... will have to be the same, so "scale" command will not work as it will just "shrink" the drawing. I know I'll probably have to shift a few things after the change.
The problem I have is I have a about ten 1:100 drawings and need to do MANY detail layouts of different rooms in 1:50 scale on each drawing. Everything is already drawn in 1:100 scale and I need to make it 1:50 scale. :(
Another problem I see is that the blocks are in scale=2 while the text is in 200mm height, so not exactly straight forward.
So basically I need to scale the whole drawing down while keeping the basepoints of all the blocks/text/leaders/lines,etc the same. Please help.
  • Replies 20
  • JeepMaster
    8
  • Lee Mac
    7
  • flowerrobot
    2
  • lpseifert
    1
Can't you use viewports with different scale factors?
Would def. make life a lot easier.
Haaa, I wish it was that simple. Our company standard has certain size of block/text/arrow size/etc. So if I just use the viewport, everything will be double in size.:(
I don't know if you created these drawings, or if you inherited them, but this is a perfect example of why you should Always draw at 1:1. :wink:
Actually, this is a floor plan with electrical symbols. So can't really draw 1:1. If it was a detail of an equpiment, then yes always 1:1.
Written quickly, just an idea really, may need more filters:
(defun c:sclAll (/ *error* BLKS DOC ENT I MA MI OBJ PTLST SCL SS UF)
 (vl-load-com)
 (defun *error* (msg)
   (and uF (vla-EndUndoMark doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (setq blks (vla-get-Blocks
              (setq doc (vla-get-ActiveDocument
                          (vlax-get-acad-object)))))
 (initget 7)
 (setq scl (getreal "\nSpecify Scale Factor: "))
 (if (setq i -1 ss (ssget "_:L"))
     (setq uF (not (vla-StartUndoMark doc)))
     (while (setq ent (ssname ss (setq i (1+ i))))
       (setq obj (vlax-ename->vla-object ent))
       (cond (  (eq "INSERT" (cdr (assoc 0 (entget ent))))
                (if (not (eq :vlax-true
                           (vla-get-isXRef
                             (vla-item blks (vla-get-Name obj)))))
                  (vla-ScaleEntity obj
                    (vla-get-InsertionPoint obj) scl)))
             (  (wcmatch (cdr (assoc 0 (entget ent))) "*TEXT")
                  (vlax-get-property obj
                    (if (eq "AcDbText" (vla-get-ObjectName obj))
                      (if (eq acAlignmentLeft (vla-get-Alignment obj))
                            'InsertionPoint 'TextAlignmentPoint) 'InsertionPoint)) scl))
             (t (vla-getBoundingBox obj 'Mi 'Ma)
                (setq ptLst (mapcar (function vlax-safearray->list) (list Mi Ma)))
                  (vlax-3D-point
                    (polar (car ptLst)
                              (apply (function angle)    ptLst)
                           (/ (apply (function distance) ptLst) 2.))) scl))))
     (setq UF (vla-EndUndoMark doc))))
 (princ))
 (vl-load-com)
   (princ))
 (initget 7)
                           (vla-get-isXRef
                  (vlax-3D-point
                    (polar (car ptLst)
 (princ))
Wow Lee, thanks so much. That seems to do the trick for the most part. The only thing I notice is the arrows gets screw up. The leader lines changes somehow. Also, can the arrow head size be scaled by the same factor?:D You are the best!:P
Might have to just add a filter for them in the COND statement, and do them another way.
 (vl-load-com)
   (princ))
 (initget 7)
                           (vla-get-isXRef
             (  (wcmatch (cdr (assoc 0 (entget ent))) "*LEADER"))
                  (vlax-3D-point
                    (polar (car ptLst)
 (princ))
Annatotive?
You mean annotative. Yes, it's an electrical power plan for a building, so it will have text, electrical symbols, notes with leaders, etc.
Lee, the only thing I can't figure out is how to include the arrowhead on the leaders so the arrowhead size will be scaled up/down too. Right now after I run the lisp, I'll have to select all the leaders and manualy change the arrow head size to the correct size from the properties window. DIMASZ only works if the leaders are drawn afterwards.
Ok, not sure if this suits?
 (vl-load-com)
   (princ))
 (initget 7)
                           (vla-get-isXRef
                  (vlax-3D-point
                    (polar (car ptLst)
                (if (wcmatch (cdr (assoc 0 (entget ent))) "*LEADER")
                  (vla-put-ArrowHeadSize obj (* (vla-get-ArrowHeadSize obj) scl))))))
 (princ))
Thanks Lee for the quick response, this seems work for the arrow head sizing, but the leaders are back to being screwy again like what happen from the first version of this lisp. The middle points of the leader are moved. Maybe if you can use the same method on the arrowheads only but added to the previous version. This lisp is way above my skills.
Bear in mind that the other LISP doesn't scale the leaders at all... This one scales the Leaders using the mid-point of the bounding box.
I shall try one more :)
If this doesn't work, then I don't know what to do...
 (vl-load-com)
   (princ))
 (defun vlax-list->3D-point (lst)
   (if lst
     (cons (list (car lst) (cadr lst) (caddr lst))
           (vlax-list->3D-point (cdddr lst)))))
 (initget 7)
                           (vla-get-isXRef
             (  (eq (cdr (assoc 0 (entget ent))) "LEADER")
                  (vlax-3D-point
                    (last
                        (vlax-safearray->list
                          (vlax-variant-value
                            (vlax-get-property obj 'Coordinates)))))) scl)
             (  (eq (cdr (assoc 0 (entget ent))) "MULTILEADER")
                  (vlax-3D-point
                    (last
                          (vlax-variant-value
                            (vlax-invoke-method obj 'GetLeaderLineVertices 0)))))) scl))
                  (vlax-3D-point
                    (polar (car ptLst)
 (princ))
Thanks Lee again. It seems like the mid point is moved further away from the original spot than the previous version. Maybe whatever you did, do it the opposite?!? Or maybe I'm just talking out of my @ss.
I just the start vertex of the Leader Line, i.e. the arrow point.
I shall try the end, as its not too hard to incorporate.
Doesn't seem to work either. Leaders are still getting wired mid point. Its ok if it's too much. I don't want waste too much of your time. Thanks for trying Lee.
Blocks(symbols), Text, Leaders, all will work in annotative
