gilsoto13 Posted January 11, 2010 Posted January 11, 2010 Weeeell, a little while ago, I bothered Lee, then I bothered alan and then I bothered everyone to help me out to build this lisp.... to do exactly as you want. Scale all mtext, text, dimensions, leaders and our standard blocks based on the current dimscale factor... if you change the dimscale factor, it will help you to update all at once. It will work for you if you use the dimscale factor as the base factor, or you can use some of this code to scale leaders... might not help.. but this thread has a similar purpose. look for du.lsp at the end of this page http://www.cadtutor.org/forum/showthread.php?t=40976&page=3 Quote
