Mysterious Circles Out of Nowhere
What is up with that? All of a sudden these circles appear at intersections and end of lines. They are red in color and maintain their size when zooming in or out. They are also not selectable! They disappear when using a selection or crossings window. They are also not at every intersection on EOL.
When did this start happening?
If it just started today, have you tried rebooting?
Have you loaded any new software recently that might be causing a conflict?
Can you post a screenshot of these circles?
Does this occur in all drawings you open or just in a particular drawing? If it is limited to a single drawing what is the source of the drawing? Did you obtain it from another firm or from the client?
AutoCad is telling you that their are unclosed boundaries. Usually when your trying to hatch. Try regen all and see if they go away.
KC
Is that something new in 2010? I've never seen that before. :unsure:
Could it be the geometry constraint? Did you accidentally activate the automatic constraint feature?
  • 2 weeks later...
Got it. Thanks all. It was as Kencaz said.
