How to use wildcards in Text Strings
(if (= (strcase txt) "AC")
   (setq txt "PV")
When the raw discription of the point matches AC then this will set a text entitiy of PV. My problem is that this will only work if the text string matches word for word. Is there a way to word this so that I can use a wildcard.. Say for example any text string that contains AC set txt to equal PV.
Examples ED AC, AC GB, AC, etc these would all need to equal PV
I am using Autocad Landdesktop 2006, I am not very good at this lisp stuff any help would be appreciated.
Maybe...
(setq txt "externalgboundary") ;; this one contains GB
(setq txt (if (wcmatch (strcase txt) "*ED*,*AC*,*GB*") "PV" txt))
"PV"
But wait for the lisp masters... and on the mean time have a look about 'wcmatch'
HTH
Have a look at wcmatch function
(if (wcmatch (strcase txt) "*AC*")
OOps Same with LE's post above
   (setq txt "PV")
If you know regex (grep) you will be fine. As commented above the wcmatch function is your best bet but regex style expressions can be used in selection sets
ollie
But wait for the lisp masters....
But you had already arrived... :P
One more:
(if (vl-string-search "AC" (strcase txt))
   (setq txt "PV")
  • 4 years later...
I'm new to lisp routines and trying to use wildcard in lisp to rename bunch of Text Style names and change a common part of them (similar to find & Replace, but can't get it to work. Maybe I'm doing something wrong?
For example, I have Text Style names something like:
T10206-UC07-P0ZEN-110001-R7A-WIP$0$_HZTXT
T10206-UC07-P0ZEN-110001-R7A-WIP$0$ARIAL
T10206-UC07-P0ZEN-110001-R7A-WIP$0$GHS
T10206-UC07-P0ZEN-110001-R7A-WIP$0$HG
And I want to remove the "T10206-UC07-P0ZEN-110001-R7A-WIP$0$"
_HZTXT
ARIAL
GHS
HG
or atlest change this sh#t to something meaningful i.e. "Old"
Old_HZTXT
Old ARIAL
Old GHS
Old HG
This is what I have written so far (ok, :? :oops: this may look stupid… but as I told you I’m new to lisps ):
(setq txtStyleName (tblobjname "style" (if (wcmatch (strcase txt) "T10206-UC07-P0ZEN-110001-R7A-WIP$0$*"))"))
(if (/= txtStyleName nil)
(command "-RENAME" "Style" "txtStyleName" ""))
OR
(command "-RENAME" "Style" "txtStyleName" "Old"))
But none of these works.. :twisted::twisted:
Something like this perhaps
(while (setq St (tblnext "STYLE" (null St)))
 (setq StLst (cons (strcase (cdr (assoc 2 St))) StLst))
);; while
(foreach st StLst
 (if (wcmatch st "T10206-UC07-P0ZEN-110001-R7A-WIP$0$*")
     (setq i 0)
     (while (setq pos (vl-string-search "$" st i))
(setq i (1+ pos))
     );; while
     (setq newst (substr st (1+ i)))
     (command "-RENAME" "Style" st (strcat "Old " newst))
   );; progn
 );; if
);; foreach
HTH
Henrique
