Dear All,
Plz Chk the My 2nd program room size (working on mm drg only)
(written start @ sep09 finished in jan10 because im poor in written autolisp & english)
Request
add function pick point
Problem in lisp not working in feet & mt. drg
(program written help me aarya & aastha)
Thanks
rm1.LSP
Hi,
Please put your code in
 tags:
[code]
;----program concept by sachin, written by Aarya & Aastha --------------;
(defun c:Rm1 (/ roomname roomsz)
  (defun roomname ()
  (textpage)
  (princ "\nROOMNAME OPTIONS: ")
  (princ "\n\t Living   Kitchen    Bed     Toilet ")
  (princ "\n\t Office   SHop       STore   STUdy  ")
  (princ "\n\t Dining   Puja       BAth    W.c. = WC  ")
  (princ "\n\t LIft = LT    LObby      S.toi.  Living/dining = LD ")
  (princ "\n\nPress any key to return to your drawing ")
  (grread)
  (princ "\r                                          ")
  (graphscr)
  )       ;End of roomname
  (defun roomsz (/ p1 p2 p3 p4 x x1 y y1 tx h ht1 rm op pl pm tm ft rsz pll)
    (if (null txlay)
      (setq txlay "tx")
      (setq txlayer (tblsearch "layer" txlay))
    (if (null txlayer)
          (setq txlay (getstring "\nLayer name for TEXT : "))
          (setq txclr (getstring (strcat "\nColor for " txlay " layer: ")))
          (command "layer" "m" txlay "c" txclr "" "")
      (prompt "\nTEXT ON TX LAYER")
  (setvar "osmode" 32)
  (menucmd "p0=filters") (menucmd "p0=*")
  (if (null ht) (setq ht "250"))
  (setq p1 (getpoint "\nPick room corner: ")
        p2 (getcorner p1 "\nPick Diagonally opposite corner: ")
        p3 (list (car p2)(cadr p1)) p4 (list (car p1)(cadr p2))
        a  (distance p1 p3) b (distance p1 p4)
        x  (* 0.001 a) y (* 0.001 b) x1 (rtos x 2 2) y1 (rtos y 2 2)
        mt (strcat x1 "x" y1))
  (setq ix (cvunit x "meter" "inch") iy (cvunit y "meter" "inch")
        xf (rtos ix 4 0) yf (rtos iy 4 0) ft (strcat xf "x" yf))
  (PROMPT "\nENTER FOLLOWING KEYWORD OR TY FOR TYPE")
  (setq cnt T)
  (while cnt
   (initget 1 (strcat "Living Kitchen Bed Toilet "
                     "Office SHop STore STUdy "
                     "Dining Puja BAth WC TY ? "
                     "LT LObby S.toi. LD "))
  (setq rm (getkword
     "\nROOM NAME = Liv/Bed/Kit/Toi/Off/Din/SHop/BAth/WC/STore/STUdy/S./LT/LD/LO/TYpe/?:"))
  (if (/= (type rm) 'LIST)
    (if (= rm "?")
          (roomname) (setq cnt T)
          (setq cnt nil)
          (if (= rm "LT") (setq rm "LIFT"))
          (if (= rm "LD") (setq rm "living/dining"))
          (if (= rm "WC")  (setq rm "W.C."))
           (IF (= rm "TY") (setq rsz (strcase
                               (getstring t"\nTYPE ROOM NAME: ")))
              (setq rsz (strcase rm))
    ) (setq cnt nil)
  (setq tm (strcase (getstring (strcat "\nENTER TEXT HEIGHT <" ht ">:")) t))
  (if (/= tm "")(setq ht tm))
  (setq h (atof ht) ht1 (* h 0.88888) dt (* h 1.7))
  (setvar "osmode" 0)
  (setvar "orthomode" 1)
  (setq ht1 (fix ht1))
  (setq pc (polar p1 (angle p1 p2) (/ (distance p1 p2) 2))
        pm (polar pc (* pi 1.5) (/ h 3.55))
        pt (polar pc (/ pi 2) dt) pf (polar pc (* pi 1.5) dt))
  (command "layer" "t" txlay "on" txlay "s" txlay ""
           "text" "s" "rD" "m" pt h "0" rsz)
  (setq pm2 (getpoint pm "\nENDPOINT OF TEXT: ")
       PM1 (polar pm pi (distance pm pm2))
       pf1 (polar pf pi (distance pm pm2))
       pf2 (polar pf 0  (distance pm pm2)))
  (command "text" "s" "rs" "f" pm1 pm2 ht1 mt
           "text" "f" pf1 pf2 ht1 ft )
  ) ([color=red]roomsz[/color]))
1. I cannot figure out what your problem is, the lisp does not seem to be working but if we do not know what the program should do...:unsure:
2. You have used a local variable "roomsz" as a function -> that won't work for shure
3. I get a "right click pop up" with osnap points, is that meant to be.
Please describe your problem. :)
This is fine, you can declare a function as local, I do this quite often. :)
Huh? I thought that this wouldn't work, also the VLIDE editor showed me the "bug". Hmm...
Perhaps the code isn't right - but certainly the act of localising functions is correct.
