"Visibility" option is grayed-out
Hi,
I have a query. In the browser, if you click RMB on a file tree a context menu shows and an option "Visibility" is available. But, on my drawing ".idw" the option "Visibility" was grayed-out!
How do I make it visible?
I already figured it out... :D User error...:lol:
  • 1 month later...
I think I need to re-open this issue. I do want to turn the visibility of the other components but, the option "Visibility" was greyed out.
Any heads on this matter.
Any help on this matter, would really appreciate.
Not really sure. How were your views created. I noticed in your tree you have a view nested within a view. Not sure that Ive seen that before. I tried to recreate your issue with no luck. Do other parts/assemblies in that assembly have the same issue, or only the frame?
Got this solution from Autodesk Discussion Group.
***Within the View Properties, check the "Associative"
box setting.
