zera Posted January 7, 2010 Posted January 7, 2010 How can I open multiple scripts using a master script? Example of what i have now: ;Master Script script "C:/Documents/Test1.scr" script "C:/Documents/Test2.scr" script "C:/Documents/Test3.scr" Thanks, any help is appreciated, Quote
dbroada Posted January 7, 2010 Posted January 7, 2010 when I last looked it was impossible. Calling a second script suspends the first one permanently. There are ways round it but I can't remember what we used to do. I think the easiest was to wrap the calls into a LISP. Its a long time since I have used LISP but it was something like.... (c:defun Scripter (command "script" "Test1.scr") (command "script" "Test2.scr") (command "script" "Test3.scr") (princ) ) then call scripter from the command line Quote
nukecad Posted January 7, 2010 Posted January 7, 2010 I've done similar in the past on a toolbar button. eg ^C^C filedia 0 scr script1 scr script2 scr script3 filedia 1 Quote
zera Posted January 7, 2010 Author Posted January 7, 2010 Dave, The LISP loads successfully but just runs the last script in the line. Is there anyway to debug the lisp to run the scripts in succession? (c:defun Scripter (command "script" "Test1.scr") (command "script" "Test2.scr") (command "script" "Test3.scr") (princ) ) Eric Quote
todouble22 Posted January 7, 2010 Posted January 7, 2010 Dave,The LISP loads successfully but just runs the last script in the line. Is there anyway to debug the lisp to run the scripts in succession? (c:defun Scripter (command "script" "Test1.scr") (command "script" "Test2.scr") (command "script" "Test3.scr") (princ) ) Eric I would suggest checking where all your scripts are located? Maybe just test3.scr is in your local directory? when I try it from the command line it asks: Enter script file name Documents\Drawing1.scr>: **make sure they are in the right directory? Quote
dbroada Posted January 7, 2010 Posted January 7, 2010 Dave,The LISP loads successfully but just runs the last script in the line. Is there anyway to debug the lisp to run the scripts in succession? (c:defun Scripter (command "script" "Test1.scr") (command "script" "Test2.scr") (command "script" "Test3.scr") (princ) ) Eric TBH, its so long since I wrote LISP I can''t remember. I think I got it wrong above in that there should(?) be a () after Scripter in the first line. And your script name can include the path you specified, UI was just being lazy. Hopefully somebody with more experience will be along in a minute... LEE!? Quote
lpseifert Posted January 7, 2010 Posted January 7, 2010 untested... (defun c:Scripter () (command "script" "Test1.scr") (command "script" "Test2.scr") (command "script" "Test3.scr") (princ) ) Quote
todouble22 Posted January 7, 2010 Posted January 7, 2010 (defun c:Scripter() ;is the first line that defines the new command Scripter (command "script" "C:/Documents/Test1.scr") ; these next 3 lines call the script you need the file path (command "script" "C:/Documents/Test2.scr") (command "script" "C:/Documents/Test3.scr") (princ) ) ;then call the command scripter from the command line Quote
