johnshar123xx Posted January 7, 2010 Posted January 7, 2010 Using AutoCAD 2007 I have been looking for a lisp that puts tick marks at all radius ends that are selected. I found this lisp and it works great but the only thing is it only works on arc objects and not on arcs within polylines. I was wondering if anyone would be able to help me alter the lisp I have provided, to give it the ability to put tick marks at the ends of all radii that are within polylines. For example a polyline that consists of lines and arcs that are joined together. Thank You endtick.dwg endtick.lsp Quote
ollie Posted January 7, 2010 Posted January 7, 2010 You could use something similar to this i'd imagine ;;Not tested ;Get ent (setq ent (vlax-ename->vla-object (car(entsel)))) ;get coordinates (setq coords (vla-get-coordinates ent)) ;get vertice count ;--There is probably a ubound function to get the limit (setq limit (/ (length(vlax-safearray->list(vlax-variant-value coords))) 2)) ;set counter (setq cntr -1) (while(< (setq cntr (1+ cntr)) limit) (if(/= (vla-getbulge ent limit) 0,0) (progn ; the cntr value is the index of a bulge if the condition is met (setq tickPoint (vla-get-coordinate coords cntr)) ;add your tick here ) ) ) NOTE: your attachment throws arx not found erros on load and only shows a single line Ollie Quote
johnshar123xx Posted January 8, 2010 Author Posted January 8, 2010 Thank you Ollie for your response. I apologize, I am still not too familiar with lisps, would you be able to show me where to add the above code you supplied with the lisp I supplied below. Also in your code, do I need to supply a tick.dwg drawing or do I still use the one (endtick.dwg) that came with the endtick.lsp I found? Thanks again for your help. ;;; ENDTICK.LSP ;;; ;;; Copyright 2006 Thomas Gail Haws ;;; This program is free software under the terms of the ;;; GNU (GNU--acronym for Gnu's Not Unix--sounds like canoe) ;;; General Public License as published by the Free Software Foundation, ;;; version 2 of the License. ;;; ;;; You can redistribute this software for any fee or no fee and/or ;;; modify it in any way, but it and ANY MODIFICATIONS OR DERIVATIONS ;;; continue to be governed by the license, which protects the perpetual ;;; availability of the software for free distribution and modification. ;;; ;;; You CAN'T put this code into any proprietary package. Read the license. ;;; ;;; If you improve this software, please make a revision submittal to the ;;; copyright owner at [url="http://www.hawsedc.com"]www.hawsedc.com[/url]. ;;; ;;; This program is distributed in the hope that it will be useful, ;;; but WITHOUT ANY WARRANTY; without even the implied warranty of ;;; MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the ;;; GNU General Public License on the World Wide Web for more details. ;;; ;;; DESCRIPTION ;;; ;;; ENDTICK inserts and aligns the ENDTICK block at the endpoint of every arc or line ;;; in a selection set. It removes duplicate ticks. ;;; ;;; ENDTICK is useful for surveying and civil engineering plans to demarcate points of ;;; curvature, tangency, et cetera. ;;; ;;; You can make your own ENDTICK block if you prefer some custom shape or size tick. ;;; The default ENDTICK block is a one unit long vertical line with its insertion point ;;; at its midpoint. ENDTICK scales the ticks to the dimension text height ;;; (dimscale * dimtext), so the default ENDTICK block will look as big as the current ;;; dimension text height. ;;; ;;; Revisions ;;; 20060914 TGH Version 1.0PR released. 3 hrs. Works only with world UCS and View (defun c:ENDTICK () (ENDTICK)) (defun ENDTICK ;;No global variables. All the variables should be listed here as local. (/ CENPOINT DS DT ENDANG ENDPOINT ENTLIST ENTNAME ENTTYPE I MINTICKSEPARATION RADIUS SS1 STARTANG STARTPOINT TICKLIST TS ) ;;Set initial variables (setq ds (getvar "dimscale") dt (getvar "dimtxt") ts (* ds dt) ;;If endpoints are closer together than the distance given below ;; and also aligned angularly closer than the angular difference below, ;; ENDTICK only plots the first one of them it finds. mintickseparation (* ts 0.01) ;;In radians. Setting to some big number like 10 (larger than 2 pi) will remove coincident ticks even with different rotations. mintickangulardif 0.01 ) ;;Get selection set from user. Limit to lines and arcs. (setq ss1 (ssget '((0 . "LINE,ARC"))) i -1 ) ;;Get endpoints and orientations from selection set (while (setq entname (ssname ss1 (setq i (1+ i)))) (setq entlist (entget entname) enttype (cdr (assoc 0 entlist)) ) (cond ((= enttype "LINE") (setq startpoint (cdr (assoc 10 entlist)) endpoint (cdr (assoc 11 entlist)) ticklist (ENDTICK-addtolist (list startpoint (angle startpoint endpoint)) ticklist mintickseparation mintickangulardif ) ticklist (ENDTICK-addtolist (list endpoint (angle endpoint startpoint) ) ticklist mintickseparation mintickangulardif ) ) ) ((= enttype "ARC") (setq cenpoint (cdr (assoc 10 entlist)) radius (cdr (assoc 40 entlist)) startang (cdr (assoc 50 entlist)) endang (cdr (assoc 51 entlist)) startpoint (polar cenpoint startang radius) endpoint (polar cenpoint endang radius) ticklist (ENDTICK-addtolist (list startpoint (+ startang (/ pi 2))) ticklist mintickseparation mintickangulardif ) ticklist (ENDTICK-addtolist (list endpoint (+ endang (/ pi 2))) ticklist mintickseparation mintickangulardif ) ) ) ) ) (setq auold (getvar "aunits")) (setvar "aunits" 3) (foreach tick ticklist (command "._insert" "endtick" (car tick) ts "" (cadr tick)) ) (setvar "aunits" auold) ) (defun ENDTICK-addtolist (tick ticklist mintickseparation mintickangulardif / dupfound templist tickcheck ) ;;Look for duplicates in list (setq templist ticklist) (while (setq tickcheck (car templist)) (if (and (< (distance (car tick) (car tickcheck)) mintickseparation) (< (abs (- (cadr tick) (cadr tickcheck))) mintickangulardif) ) (setq dupfound T templist nil ) (setq templist (cdr templist)) ) ) (if (not dupfound) (cons tick ticklist) ticklist ) ) Quote
