Questions on reducing triangle count in models
Hi all, happy new year:)
I'm having quite a bit of difficulty reducing one of my models. I'm using pro optimise in 3ds 2010 and it seems to help reduce my models.
But after a while the triangles seem to start adding up again by themself?:shock:
It's very frustrating.
On the same subject does anyone know the maximum triangle count that i can attach to in a model?
I need the model attached before i export it and i keep getting errors that max has ran out of memory.
cheers
What are your computer specs? How much RAM do you have?
What is the total poly count for your scene?
Have you thought about breaking your model into smaller chunks and then attaching the smaller pieces one by one?
I attached smaller pieces and eventually the item did attach cad,thanks again for your help:)
