Having this problem with Inventor leaving kinda a trail when my mouse pauses for a sec or so then it refreshes when i zoom or draw something. Been looking for a fix for this all day and it's driving me crazy. I am running windows7 64bit. This is what it looks like. Thats a picture before i have even placed a line. every spot i pause for even a fraction of a second leaves a line when in the line tool.
You might try going to Tools>Application Options>Hardware tab and set to lowest setting.
I am running SP3 but it did the same thing on sp1 and sp2 and before sp1. i dont see any settings under hardware other than software or direct 3d and i have the same problem with both. This is such a pain.
  • 4 weeks later...
Do you have multiple ATI video cards in Crossfire? If so, disable Crossfire. That cured a LOT of visual issues for me.
I only have one video card Nvidia GeForce GTX260 I am starting to get used to it messing up but the other day i was running a game and Inventor at the same time and it was even worse as in made copies of the line way more often. It also does it when i go to place a part in a assembly. Thanks for the suggestion tho.
In your Nvidia control panel what are you image settings? Do you have "let 3d application decide" checked? Also if you go into Program settings Inventor will pop up and allow you to customize your settings if needed.
I Changed it to "let 3d application decide" but didnt seem to make a diffrence =/. "Also if you go into Program settings Inventor will pop up and allow you to customize your settings if needed". i dont know where to find these program settings. If i go to tools>application settings>Hardware all i see is use direct3d or use software graphics. when i click diagnostics i get this. dont know why it is not WHQL certified it is up to date driver.
This Direct3D graphics driver is not Microsoft WHQL certified
Graphics Hardware Description: NVIDIA GeForce GTX 260
Direct3D \ Hardware Renderer
Graphics driver file nvd3dum.dll is version 8.17.11.9562
Using Full optimization (this is the recommended setting)
The display is using 32-bit color
Inventor Version:
Build: 342, Release: 2008 SP3 - Date: Tue 05/27/2008
Loaded Inventor Add-Ins:
Simulation: Dynamic Simulation
Simulation: ANSYS Workbench
Content Center
Simulation: Stress Analysis
Inventor Vault
Routed Systems: Tube & Pipe
Autodesk DWF Markup Manager
Content Center Connectivity
Content Center Item Translator
Frame Generator
Drag & Drop Interoperability
Design Accelerator
Routed Systems: Cable & Harness
AEC Exchange
AutoLimits
Inventor Studio
EDM Addin
System Information:
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7100) (7100.winmain_win7rc.090421-1700)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: EP45-UD3P
BIOS: Award Modular BIOS v6.00PG
Processor: Intel® Core™2 Duo CPU E8400 @ 3.00GHz (2 CPUs), ~3.0GHz
System Memory: 4096MB RAM
Page File: 1735MB used, 6450MB available
DirectX Version: DirectX 11
DxDiag Version: 6.01.7100.0000
Graphics Device Information:
DirectX Version: 10.0
Renderer: HAL
Adapter Description: NVIDIA GeForce GTX 260
DDI Version: 10
DDI Version Number: a
DxDiag WHQL Level: 0
Driver Signed Valid: False
Driver Signed: False
Manufacturer: NVIDIA
Chip Type: GeForce GTX 260
DAC Type: Integrated RAMDAC
Revision:
Vendor ID string: 0x000010de
Device ID string: 0x000005e2
Graphics HW Memory: 2668 MB
Display Mode: 1920 x 1080 (32 bit) (60Hz)
VendorID: 10de
DeviceID: 5e2
SubSystemID: 12603842
Revision: a1
Graphics driver file: nvd3dum.dll
Driver file version: 8.17.11.9562
WHQL Level: 0
Inventor Graphics Device Information:
Hardware Library ID: Direct3D \ 0x000010de \ 0x000005e2
Direct3D Hardware ID: 10de \ 5e2 \ 12603842 \ a1
Inventor Options Information:
Options = 0x00000000
Warning Options = 0x00000000
Inventor Hardware Library Information:
HW Library Version = $Revision: #1 $
HW Library Date = $DateTime: 2008/03/03 14:04:00 $
HW Library OS Name = Windows Vista
Inventor Hardware Library Entry Information:
Autodesk Inventor Certification Status: Unknown
Autodesk Inventor Tested Certification Status: Unknown
Graphics HW Vendor Supported for Autodesk Inventor: False
Hardware Library 2.0\0x000010de
Settings for optimized and conservative:
Workarounds: 0x00000000, 0x00000000
rating 0, optimization level 2
Texture Font Precision: 32
Display Information:
Back Buffer Format = A8R8G8B8
Depth Stencil Buffer Format = D24S8
Monochrome Bitmap Format = A8
Device Adapter Information:
AdapterOrdinal = 0
MasterAdapterOrdinal = 0
AdapterOrdinalInGroup = 0
NumberOfAdaptersInGroup = 1
Device Processing Information:
DeviceType = 1
Device Behavior = 0x00000042
Vertex Processing = Hardware
Device Transform and Light = Hardware
Device Rasterization = Hardware
Supports SlopeScaleDepthBias = True
Supports DepthBias = True
Supports CubeMaps = True
Supports Non-Power-Of-2 Textures = True
Supports Non-Power-Of-2 Textures Conditionally = False
Device Size Limits:
MaxPrimitiveCount = 8388607
MaxVertexIndex = 16777215
MaxTextureWidth = 8192
MaxTextureHeight = 8192
MaxSimultaneousTextures = 8
NumSimultaneousRTs = 4
MaxActiveLights = 8
MaxUserClipPlanes = 8
Device Shader Information:
VertexShaderVersion = 3.0
PixelShaderVersion = 3.0
MaxVertexShaderConst = 256
PixelShader1xMaxValue = 6.550400E+004
MaxVShaderInstructionsExecuted = 65535
MaxPShaderInstructionsExecuted = 65535
MaxVertexShader30InstructionSlots = 4096
MaxPixelShader30InstructionSlots = 4096
VS20Caps = 0x00000001
DynamicFlowControlDepth = 24
NumTemps = 32
StaticFlowControlDepth = 4
PS20Caps = 0x0000001f
NumTemps = 32
NumInstructionSlots = 512
The Remainder of the Device Caps Information:
Caps = 0x00020000
Caps2 = 0xe0020000
Caps3 = 0x000003a0
PresentationIntervals = 0x8000000f
CursorCaps = 0x00000001
DevCaps = 0x001bbef0
PrimitiveMiscCaps = 0x002fcef2
RasterCaps = 0x07732191
ZCmpCaps = 0x000000ff
SrcBlendCaps = 0x00003fff
DestBlendCaps = 0x00003fff
AlphaCmpCaps = 0x000000ff
ShadeCaps = 0x00084208
TextureCaps = 0x0001ecc5
TextureFilterCaps = 0x03030700
CubeTextureFilterCaps = 0x03030300
VolumeTextureFilterCaps = 0x03030300
TextureAddressCaps = 0x0000003f
VolumeTextureAddressCaps = 0x0000003f
LineCaps = 0x0000001f
MaxVolumeExtent = 2048
MaxTextureRepeat = 8192
MaxTextureAspectRatio = 8192
MaxAnisotropy = 16
StencilCaps = 0x000001ff
FVFCaps = 0x00180008
TextureOpCaps = 0x03feffff
StretchRectFilterCaps = 0x03000300
VertexTextureFilterCaps = 0x01010100
MaxTextureBlendStages = 8
DeclTypes = 0x0000030f
VertexProcessingCaps = 0x0000013b
MaxVertexBlendMatrices = 4
MaxVertexBlendMatrixIndex = 0
MaxPointSize = 8.192000E+003
MaxStreams = 16
MaxStreamStride = 255
DevCaps2 = 0x00000051
MaxNpatchTessellationLevel = 0.000000E+000
MaxVertexW = 1.000000E+010
GuardBandLeft = -1.000000E+008
GuardBandTop = -1.000000E+008
GuardBandRight = 1.000000E+008
GuardBandBottom = 1.000000E+008
ExtentsAdjust = 0.000000E+000
Reserved5 = 0x00000000
