How to add more than one testexpr to IF?
Lee I edited your routine to mach the company standards
But I want some help in
- How to append a string EC-22- with and argument Dwgscl
(setq DwgScl (getreal "\n What is Drawing Scale: 1:")
     StyleName EC-22-DwgScl
     DimName EC-DwgScl
     TextHeight (* DwgScl 2.2))
- How to restore OSMODE if hit ESC or enter
Is this code correct?
 (setq *error* TERR$)
 (setvar "osmode" OldOS)
The full routine with changes (Blue color parts which i added)
;To add the vertical ad horizantal dimensions
;which shoing the relation between columns and axes
(defun c:coldim (/ *error* DwgScl P1 P2 P3 P4 SPC TXT UFLAG)
 (vl-load-com)
 (defun *error* (msg)
   (and uFlag (vla-EndUndoMark doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
[color=blue](setq OldOS (getvar "osmode"))[/color]
[color=blue] (setvar "osmode" 33)[/color]
[color=blue] (setq DwgScl (getreal "\n What is Drawing Scale: 1:")[/color]
[color=blue]StyleName EC-22-DwgScl[/color]
[color=blue]DimName EC-DwgScl[/color]
[color=blue]TextHeight (* DwgScl 2.2))[/color]
[color=blue] (command "-style" StyleName "romans.shx" TextHeight "08" "0" "n" "n" "n"[/color]
[color=blue]   "-dimstyle" "save" DimName)[/color]
[color=blue] (setvar "DIMALTF" 25.4[/color]
[color=blue]  "DIMALTTD" 2[/color]
[color=blue]  "DIMASZ" (* 0.2 DwgScl)[/color]
[color=blue]  "DIMBLK1" oblique[/color]
[color=blue]  "DIMBLK2" oblique[/color]
[color=blue]  "DIMCEN" 0[/color]
[color=blue]  "DIMCLRD" 8[/color]
[color=blue]  "DIMCLRE" 8[/color]
[color=blue]  "DIMCLRT" 10[/color]
[color=blue]  "DIMDEC" 0[/color]
[color=blue]  "DIMDLE" (* 1 DwgScl)[/color]
[color=blue]  "DIMDLI" 8[/color]
[color=blue]  "DIMDSEP" .[/color]
[color=blue]  "DIMEXE" (* 1 DwgScl)[/color]
[color=blue]  "DIMEXO" (* 3 DwgScl)[/color]
[color=blue]  "DIMGAP" (* 1 DwgScl)[/color]
[color=blue]  "DIMLDRBLK" ClosedFilled[/color]
[color=blue]  "DIMSAH" On[/color]
[color=blue]  "DIMTDEC" 0[/color]
[color=blue]  "DIMTIX" On[/color]
[color=blue]  "DIMTMOVE" 1[/color]
[color=blue]  "DIMTOLJ" 1[/color]
[color=blue]  "DIMTXT" 12[/color]
[color=blue]  "DIMTZIN" 0[/color]
[color=blue]  "DIMZIN" 0)[/color]
 (setq doc (cond (doc) ((vla-get-ActiveDocument
                          (vlax-get-Acad-Object))))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true)
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (while (and (setq p1 (getpoint "\nPick Axes Crossing Point: "))
             (setq p2 (getpoint "\nPick Corner Point: ")))
     (setq uFlag (not (vla-StartUndoMark doc)))
     (apply (function vla-AddDimRotated)
            (append (list spc)
                    (mapcar
                      (function vlax-3D-point)
                      (list (setq  p3 (list (car p1) (cadr p2) (caddr p1))) p2
                            (polar p3 (angle p1 p3) (* DwgScl )))
      '(0.)))
            (append (list spc)
                    (mapcar
                      (list p2 (setq  p4 (list (car p2) (cadr p1) (caddr p1)))
                               (polar p4 (angle p1 p4) (* DwgScl )))
                    (list (/ pi 2.))))
   (setq uFlag (vla-EndUndoMark doc))
   ) ; while
[color=blue]; Restore OSmode [/color]
[color=blue] (setq *error* TERR$)[/color]
[color=blue] (setvar "osmode" OldOS)[/color]
[color=blue] (princ "\nProgram completed and will now restore the user settings and exit.")[/color]
; To add the vertical ad horizantal dimensions
; which shoing the relation between columns and axes and adds the column number
(defun c:coldimtxt (/ *error* DwgScl P1 P2 P3 P4 SPC TXT UFLAG)
 (while (and (setq p1 (getpoint "\nPick Center Point: "))
             (/= "" (setq txt (getstring "\nColumn Number: "))))
   (vla-AddText spc txt
       (vlax-3D-point
         (polar p2 (angle p1 p2) (sqrt (* 2. (* DwgScl  (* DwgScl )))) (getvar "TEXTSIZE"))
  • Replies 25
  • asos2000
    13
  • Lee Mac
    10
  • BearDyugin
    2
  • Tharwat
    1
Posted Images
Use
(strcat [color=red][color=black]"EC-22-" (rtos DwgScl))[/color][color=black]
[/color][/color]
  • 3 weeks later...
I updated the lisp in rudimentary way
Facing 2 problems
- Restoring errors not working
- The routine looks unrecognized
(defun c:coldim ()
 (vl-load-com)
   (princ))
 (setq OldDynmode (getvar "dynmode"))
 (setq OldDynprompt (getvar "dynprompt"))
 (setvar "dynmode" 1)
 (setvar "dynprompt" 1)
 (setvar "cmdecho" 0)
 (command "_.-units" "2" "0" "1" "0" "0" "n")
 (command "_.-insert" "C:/EC-Menu/Blocks/EC-standards.dwg" "0,0,0" "1" "1" "0")
 (command "_.explode" "last")
 (command "_.-PURGE" "blocks" "EC-standards" "n")
 (initget 0 "20 25 50 100 150")
(if (setq DwgScl (getkword "\nSpecify Drawing Scale [20/25/50/100/150]: 1:"))
   (setq TxtHght (* 3.0 (atof DwgScl)))
   (setq DwgScltxt0 (strcat "EC-30-0" DwgScl))
   (setq DwgScltxt (strcat "EC-30-" DwgScl))
   (setq DwgSclDim0 (strcat "EC-0" DwgScl))
   (setq DwgSclDim (strcat "EC-" DwgScl))
   (if (> 3 (strlen DwgScl))
(command "_.-dimstyle" "_Restore" DwgSclDim0)
(command "_.-style" DwgScltxt0 "romans.shx" TxtHght "0.8" "0" "n" "n" "n"))
     (command "_.-dimstyle" "_Restore" DwgSclDim)
     (command "_.-style" DwgScltxt "romans.shx" TxtHght "0.8" "0" "n" "n" "n")))))
     (command "_.-units" "2" "2" "1" "0" "0" "n")
 (initget 0 "Yes No")
(if (setq ColNmber (getkword "\nDo You Want to Add Column Number? [Yes/No] "))
 (if (> 3 (strlen ColNmber))
            (append (list spc)
                    (mapcar
                            (polar p3 (angle p1 p3) (* (atof Dwgscl) )))
      '(0.)))
            (append (list spc)
                    (mapcar
                               (polar p4 (angle p1 p4) (* (atof Dwgscl) )))
                    (list (/ pi 2.))))
   (setq uFlag (vla-EndUndoMark doc))))
      (/= "" (setq txt (strcase (getstring "\nSpecify Column Number: ")))))
       (append (list spc)
        (mapcar
      '(0.)))
            (append (list spc)
                    (mapcar
                    (list (/ pi 2.))))
(command "clayer" "EC-TEXT-30-SCALE")
       (vlax-3D-point
         (polar p2 (angle p1 p2) (sqrt (* 2. (* (atof Dwgscl)  (* (atof Dwgscl) )))) TxtHght)
(command "clayer" "EC-DIM-SCALE")
 (setvar "dynmode" OldDynmode)
 (setvar "dynprompt" OldDynprompt)
 (princ "\nProgram completed and will now restore the user settings and exit."))
  • 9 months later...
Is there a solving for this error
Adding TRANS does not solve this error
(setq p1 (trans (getpoint "\nPick Axes Crossing Point: ") 1 0))
Hope you get your routine worked afterall . :lol:
Example . Take a deep look. :)
(setq pt1 (getpoint "\n First point :"))
(setq pt2 (getpoint pt1 "\n Second Point :"))
(setq pt3 (list (+ (car pt1) 1.)(cadr pt1)))
(command "_.dimaligned" pt1 pt2 pt3)
Merry Christmas guys.
