add baction with lisp
hello again.
I am wanting to run a lisp inside the block editor to create a dynamic block..
I can setup the parameters but when it comes to assigning an action to these properties, I can't!
I am trying to insert the entity name of the parameter (eg a point parameter) in an acad command line :
(command "baction" ParameterEntityName ....)
but it doesn't select the entity - the only way I can is by manually selecting, which defeats reason for lisp..
These dynamic block properties seem a bit different as they don't have any other info besides their enames (-1 data) in the entget so I had to get the data through vlisp.
anyone got any ideas on how to assign an action to a property with lisp in a dynamic block?
Cheers
Martin
mmmm... think i just made it work
(command "baction" esel "move" "all" "")
Sorry about that post but I thought i had tried that but maybe I only tried
(command "baction" "move" esel "all" "") , which doesn't work.
where esel is the entsel. I have to create one I think:
(setq esel-bp-point-move-all (list ename-bp-point-move-all (list 0 0 0)))
(command "BAction" esel-bp-point-move-all "move" ss "")
..anyway, it appears to work now so all good
thanks
