asos2000 Posted January 11, 2010 Posted January 11, 2010 How to convert DVB file to be an excutable file Quote
ReMark Posted January 11, 2010 Posted January 11, 2010 I've read that to create an EXE you need full VB. Quote
SEANT Posted January 11, 2010 Posted January 11, 2010 A DVB can't be compiled directly to an executable. It will have to be re-written in VB6, then compiled from there. Edit: Yeah, like ReMark said. Quote
ReMark Posted January 11, 2010 Posted January 11, 2010 Maybe this might be of some interest to you. http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=2878515&linkID=9240617 Just what is it you are trying to do? Quote
asos2000 Posted January 11, 2010 Author Posted January 11, 2010 Mr ReMark I have full VB (IT Department) this link to embedded not to convert to EXE See attached What I want is same like this. PS: Ignore the language just click the button then in next window type a number then go to AutoCAD and pick points it will add the numbers in sequence Nmbr.zip Quote
suns_444 Posted November 22, 2013 Posted November 22, 2013 hi could you give the source code for above attachment Quote
