chavlji Posted January 11, 2010 Posted January 11, 2010 Hello I recovered a drawing and now every time i want to INSERT with insert dialog ACad freezes. "$AUDIT_BAD_BLOCK_RECORD" is the first block and it freezes while trying to create it's thumbnail... How to get rid of "$AUDIT_BAD_BLOCK_RECORD" block? I tried purge, but this block is not showned. I tried to QSelect this block but no instance is found... how to delete it ?!? Quote
ReMark Posted January 11, 2010 Posted January 11, 2010 This is what AutoDesk recommends: http://usa.autodesk.com/adsk/servlet/ps/item?siteID=123112&id=12056161&linkID=9240617 Quote
chavlji Posted January 11, 2010 Author Posted January 11, 2010 It worked!!! On the command line, enter -PURGE Note: Be sure to include the hyphen. When prompted, enter B When prompted to "Enter names to purge," press ENTER. When prompted to "Verify each name to be purged?" enter N. thenx man! Quote
ReMark Posted January 11, 2010 Posted January 11, 2010 Well that makes two of us that are happy that it did. You're entirely welcomed. Quote
