Lisp to select leaders and change arrowsize
I'm trying to figure out how to select a group of leaders and manually change the arrowhead size by a certain factor. This is somewhat of a continuation from the results of this thread.
http://www.cadtutor.net/forum/showthread.php?t=43478
The sclall.lsp from LeeMac is good. I just need to select the leaders afterwards and manually change the arrowhead size by a set factor. So if I can figure out another lisp that will resize the arrowhead size, that would save me a few more steps than doing the properties menu method. Thanks.
Try this:
(defun c:aSze (/ *error* scl uFlag ActiveSelSet)
 (vl-load-com)
 (setq doc (cond (doc) ((vla-get-ActiveDocument
                          (vlax-get-Acad-Object)))))
 (defun *error* (msg)
   (and uFlag (vla-EndUndomark doc))
       (princ (strcat "\n** Error: " msg " **")))
   (princ))
 (if (and (setq scl (getreal "\nSpecify Scale Factor: "))
          (ssget "_:L" '((0 . "*LEADER"))))
     (setq uFlag (not (vla-StartUndoMark doc)))
     (vlax-for object (setq ActiveSelSet (vla-get-ActiveSelectionSet doc))
       (vlax-put-property object 'ArrowHeadSize
         (* (vlax-get-property object 'ArrowHeadSize) scl)))
     (vla-delete ActiveSelSet)
     (setq uFlag (vla-EndUndoMark doc))))
 (princ))
That is awsome Lee. Exactly what I wanted. Thanks so much. LeeMac to the rescue...AGAIN.:D
You're welcome Jeep :)
