humaironline Posted January 12, 2010 Share Posted January 12, 2010 I want to repeat the stair railings by using 3d Array or any other command. Kindly help me out to do it. stair = L3' x W8" x h8" waiting a quick response.... Quote Link to comment Share on other sites More sharing options...
amit87 Posted January 12, 2010 Share Posted January 12, 2010 I would be interested to know how this works too! Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 12, 2010 Share Posted January 12, 2010 Why don't you just copy the objects, select both stantion posts, and use the toe of the step as your base point. It would probably take more time and to much effort to set up an array, besides this I don't think array can be used to go up at an inclined angle. Quote Link to comment Share on other sites More sharing options...
humaironline Posted January 12, 2010 Author Share Posted January 12, 2010 its ok stevsmith...but i want to learn the 3d array ....by this problem. I hope any one will help me soon to solve this issue. so waiting.... Quote Link to comment Share on other sites More sharing options...
iskalipsi Posted January 12, 2010 Share Posted January 12, 2010 I agree with what steve said.Copy would be easier. Quote Link to comment Share on other sites More sharing options...
humaironline Posted January 12, 2010 Author Share Posted January 12, 2010 I tried but its not easier, to place on face. cross hair not select face easily..so I need to place a line on every step. so its better we solve it by array or other useful command. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 12, 2010 Share Posted January 12, 2010 3D arrays are pretty simple. Click on 3d Array Select the object. Select whether you want a rectangular Array or polar Array. Rectangular array Enter number of rows - This is the number of items along the "y" axis Enter the number of columns - this is the number of items along the "x" axis Enter the number of levels - this is the number of items along the "z" axis Specify each distance. Polar Enter the number of items in array - how many items do you want Specify the angle to fill - (+ 275 means anti clockwise 275deg) (-275 means clockwise) Rotate arrayed object - lets the cpu know if the the objects are to be turned along path of array. Specify the centre point. specify your axis - for the objects to be rotated around. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 12, 2010 Share Posted January 12, 2010 I tried but its not easier, to place on face. cross hair not select face easily..so I need to place a line on every step. so its better we solve it by array or other useful command. Trust me, I design staircases for a living. Copy is the easier method. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 12, 2010 Share Posted January 12, 2010 try this, copy from the corner point of the tread and not the face Quote Link to comment Share on other sites More sharing options...
humaironline Posted January 12, 2010 Author Share Posted January 12, 2010 ya....nice...thanks....every one...i have done it by using 2d array.... stevsmith...your last trick is also very good... now the problem is to draw a continues hand railing...that run on top of every pole.... can any one help to draw spline on them...i tried but it not look good. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 12, 2010 Share Posted January 12, 2010 you have to orientate the ucs icon to go with the angle of the stair, this will allow you to draw a handrail and extrude it along it's path. please note that this is only a quick example. I'm at work and don't have the time for a full on tutorial. but it is best to explore ucs manipualtion. It can be a pain at 1st, but it's worth it Quote Link to comment Share on other sites More sharing options...
humaironline Posted January 13, 2010 Author Share Posted January 13, 2010 i tried many time by spline, polyline, and also by line but unable to do yet. pls check the attached dwg file. and give me the proper solution to draw hand rail... My bedroom.dwg Quote Link to comment Share on other sites More sharing options...
iskalipsi Posted January 13, 2010 Share Posted January 13, 2010 Try to draw a 3DPOLY.First point on the top center of your stair baluster then the second on the bottom center. And then use SWEEP for your hand rail. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 13, 2010 Share Posted January 13, 2010 as iskalipsi says, use a 3DPOLY. Quote Link to comment Share on other sites More sharing options...
humaironline Posted January 13, 2010 Author Share Posted January 13, 2010 ya...good iskalipsi...i have done it..but 3dpoly do not get curve by fillet... any help ....in this regard... Quote Link to comment Share on other sites More sharing options...
humaironline Posted January 21, 2010 Author Share Posted January 21, 2010 I want to apply material on inside wall, but when I apply it spread on whole wall. Pls tell me any way to apply separately. see the attachment. humair. Quote Link to comment Share on other sites More sharing options...
iskalipsi Posted January 23, 2010 Share Posted January 23, 2010 i would create a thin wall for the other material.. Quote Link to comment Share on other sites More sharing options...
melox Posted January 24, 2010 Share Posted January 24, 2010 You could open your Materials pallette, click on the material you want to apply whilst holding the control key and drag it to the face you want to Render. Hopefully that helps you my friend. Quote Link to comment Share on other sites More sharing options...
humaironline Posted January 25, 2010 Author Share Posted January 25, 2010 Yah...thats was a good idea...thanks melox... iskalipsi...see the advice of melox... thanks....again...now i got ...it.. Quote Link to comment Share on other sites More sharing options...
iskalipsi Posted January 26, 2010 Share Posted January 26, 2010 Yah...thats was a good idea...thanks melox...iskalipsi...see the advice of melox... thanks....again...now i got ...it.. nice tip.Ill try that. thanks. Can you post a finish picture of your render? Quote Link to comment Share on other sites More sharing options...
