Hi,
I do not use annotative scaling (yet) but I might in the near future.
For now I only want to know this so I can move on:
How come that elements (dimension or leaders) that are annotative are not displayed in a viewport in paperspace.
The layers are all on, thaw, "plot" etc...
When using the properties palette I can see that these elements are set to be annotative (yes). I select the elements and put the annotative steting to no. Then they are displayed.
Why?
My problem is that I cannot be shure everything is being plotted in the viewports. I must double check all viewports before plotting.
Any help is much appreciated. Tnx.
Hi NBC,
Thanks for reply! It is exactly what I meant, my problem is solved. :)
To be shure that every drawing is "at least" opened with ANNOALLVISIBLE I will pute a piece of code in a startuproutine.
I have read through the help section within autocad wich explains a specific toolbar button:
I remember using this but I did not notice any change.
Now I know!
Tnx again.
