tutt Posted January 13, 2010 Share Posted January 13, 2010 It doesn't show as a workspace alternative, the only choice I have is "architecture". Thx Quote Link to comment Share on other sites More sharing options...
Tiger Posted January 13, 2010 Share Posted January 13, 2010 If you go into Tools > Options > Workspace, is it listed there? Quote Link to comment Share on other sites More sharing options...
tutt Posted January 13, 2010 Author Share Posted January 13, 2010 Where do I find tools? I am using autocad architecture 2010 btw Quote Link to comment Share on other sites More sharing options...
Tiger Posted January 13, 2010 Share Posted January 13, 2010 Where do I find tools? I am using autocad architecture 2010 btw ach...ehm....right-click on the commandline instead and click Options. Then I see now, have AutoCAD up and running now, that you need to go to the Display-tab and click Colors to get the list of Workspaces that I'm thinking of Quote Link to comment Share on other sites More sharing options...
BearDyugin Posted January 13, 2010 Share Posted January 13, 2010 Where do I find tools? In the menu - Line in top If it is not present, a system variable menubar in 1 In a command line enter: menubar Press Enter 1 Press Enter And to replace working space it is possible having pressed a button (with the gear image) in the right bottom corner Quote Link to comment Share on other sites More sharing options...
tutt Posted January 13, 2010 Author Share Posted January 13, 2010 In the menu - Line in topIf it is not present, a system variable menubar in 1 In a command line enter: menubar Press Enter 1 Press Enter And to replace working space it is possible having pressed a button (with the gear image) in the right bottom corner It's not present, and when I use the command "menubar 1" I get "No menus are defined" and then the value remains 0. Quote Link to comment Share on other sites More sharing options...
tutt Posted January 13, 2010 Author Share Posted January 13, 2010 ach...ehm....right-click on the commandline instead and click Options. Then I see now, have AutoCAD up and running now, that you need to go to the Display-tab and click Colors to get the list of Workspaces that I'm thinking of Ok then I get it. Well thats no workspaces is it? And the workspace I'm currently using (my only choice) architecture is not listed there.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 13, 2010 Share Posted January 13, 2010 Type WORKSPACE at the command line. Next, type SE (for Settings). Does the Workspace Settings dialong box appear onscreen? Quote Link to comment Share on other sites More sharing options...
tutt Posted January 14, 2010 Author Share Posted January 14, 2010 Type WORKSPACE at the command line. Next, type SE (for Settings). Does the Workspace Settings dialong box appear onscreen? Yes, it does. But the only choice I have in the list is architecture. Is it so that you have to install the 3d modeling workspace somehow? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 14, 2010 Share Posted January 14, 2010 In plain vanilla AutoCAD the following task-based workspaces are already defined in the product: 2D Drafting & Annotation 3D Modeling AutoCAD Classic I'm puzzled as to why Arch 2010 wouldn't be set up the same way unless the default is 3D modeling with no other defined choices. That can't be the case can it? Quote Link to comment Share on other sites More sharing options...
tutt Posted January 14, 2010 Author Share Posted January 14, 2010 In plain vanilla AutoCAD the following task-based workspaces are already defined in the product: 2D Drafting & Annotation 3D Modeling AutoCAD Classic I'm puzzled as to why Arch 2010 wouldn't be set up the same way unless the default is 3D modeling with no other defined choices. That can't be the case can it? Yes, what you describe is what is seen in cadtutors "getting ready for 3d"-video introduction. Where he can change from 2d drafting to 3d modeling, I only have 1 choice which is architectural, and this workspace is not the same as the 3d modeling one. Maybe I have to define it myself? Or is there any way for someone else to save down his/her 3dmode and send it to me? Quote Link to comment Share on other sites More sharing options...
hwngirl Posted April 16, 2010 Share Posted April 16, 2010 I came across the same issue today and just figured out how to do it by browsing the options tool. For those who are using autocad 2010 architecture and are beginners like myself, this is how you activate the 3d workspace. 1) Right click anywhere in the command box near the bottom of the screen 2) Select Options 3) Click on the profiles tab note: you should see three items autocad autocad arch (imperial) autocad arch (metric) 4) Select autocad (not autocad arch imperial or metric) 5) Click "Set Current" 6) Click "ok" And voila, you should have the option to switch between the default workspaces as aforementioned in the lower right hand corner of the screen. Quote Link to comment Share on other sites More sharing options...
marios Posted October 30, 2011 Share Posted October 30, 2011 thank you VERY MUCH Quote Link to comment Share on other sites More sharing options...
NTMinh Posted March 25, 2012 Share Posted March 25, 2012 I came across the same issue today and just figured out how to do it by browsing the options tool. For those who are using autocad 2010 architecture and are beginners like myself, this is how you activate the 3d workspace. 1) Right click anywhere in the command box near the bottom of the screen 2) Select Options 3) Click on the profiles tab note: you should see three items autocad autocad arch (imperial) autocad arch (metric) 4) Select autocad (not autocad arch imperial or metric) 5) Click "Set Current" 6) Click "ok" And voila, you should have the option to switch between the default workspaces as aforementioned in the lower right hand corner of the screen. thank you very much Quote Link to comment Share on other sites More sharing options...
laracroft2 Posted April 14, 2012 Share Posted April 14, 2012 This has just brought to an end HOURS of frustration...thank you very much! Quote Link to comment Share on other sites More sharing options...
turtleninja Posted April 23, 2012 Share Posted April 23, 2012 I came across the same issue today and just figured out how to do it by browsing the options tool. For those who are using autocad 2010 architecture and are beginners like myself, this is how you activate the 3d workspace. 1) Right click anywhere in the command box near the bottom of the screen 2) Select Options 3) Click on the profiles tab note: you should see three items autocad autocad arch (imperial) autocad arch (metric) 4) Select autocad (not autocad arch imperial or metric) 5) Click "Set Current" 6) Click "ok" And voila, you should have the option to switch between the default workspaces as aforementioned in the lower right hand corner of the screen. I have the Autocad LT, i tried what u said there, but i don't have the profiles tab (step nr 3) is there something i can do? Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2012 Share Posted April 23, 2012 There is no "Profiles" tab in AutoCAD LT only in the full version. Quote Link to comment Share on other sites More sharing options...
andrewdh Posted September 25, 2012 Share Posted September 25, 2012 (edited) I came across the same issue today and just figured out how to do it by browsing the options tool. For those who are using autocad 2010 architecture and are beginners like myself, this is how you activate the 3d workspace. 1) Right click anywhere in the command box near the bottom of the screen 2) Select Options 3) Click on the profiles tab note: you should see three items autocad autocad arch (imperial) autocad arch (metric) 4) Select autocad (not autocad arch imperial or metric) 5) Click "Set Current" 6) Click "ok" And voila, you should have the option to switch between the default workspaces as aforementioned in the lower right hand corner of the screen. "Thanks a Million as you have solved a problem in the shortest method. YOUR GREAT" Edited September 25, 2012 by Tiger Quote Link to comment Share on other sites More sharing options...
TeKluse Posted November 19, 2012 Share Posted November 19, 2012 I am very glad I found this thread with the SOLUTION! thank you. Quote Link to comment Share on other sites More sharing options...
manuela sarnouk Posted December 15, 2013 Share Posted December 15, 2013 does it mean that when i want to open an architecture workspace i have to go back to options>profiles>autocad architecture(global) or (metric), or is there a way i can insert the architecture workspace beside the other workspaces in the autocad profile? Quote Link to comment Share on other sites More sharing options...
