Kat Posted January 17, 2010 Posted January 17, 2010 Hi All I am working on seating for a curved auditorium. I was wondering if there was an easy way to number them in ascending order like A1, A2 etc. Any suggestions? Thanks, Kat Quote
rkent Posted January 17, 2010 Posted January 17, 2010 Hi All I am working on seating for a curved auditorium. I was wondering if there was an easy way to number them in ascending order like A1, A2 etc. Any suggestions? Thanks, Kat Look in Express Tools, text, don't remember the exact name. Also search on web for Autonumb lisp program. cad.digitalmedianet.com/articles/viewarticle.jsp?id=7017 ConsecutiveTeXT.lsp Quote
Kat Posted January 17, 2010 Author Posted January 17, 2010 YAY! I knew there was a command to do that. The problem doesn't really come up that often though. Thank you! That will save some mouse clicking time. Quote
Tankman Posted January 18, 2010 Posted January 18, 2010 YAY! I knew there was a command to do that. The problem doesn't really come up that often though. Thank you! That will save some mouse clicking time. For your library of "useful stuff" you might like the attached lisp (file) routine. callout.lsp Quote
nukecad Posted January 18, 2010 Posted January 18, 2010 If you only have LT, or if you dont like lisps try the following two marcos- ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Put the following string on a user defined menu button. *^C^C_text;\;;$M=$(+,$(getvar,USERI1),1);setvar;US ERI1;$M=$(+,$(getvar,USERI1),1); This puts a new text with an incremented value on the drawing with each click of your mouse. You can also use SETVAR to change USERI1 to 1 below whatever initial value you want. (Many thanks to ZOOMHARIS on the AUGI forum). ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ AND this one increments text that is already on the drawing *^C^C_.Change;\;;;;;;$M=$(getvar,USERI1);_.Setvar; USERI1;$(+,1 ,$(getvar,USERI1)) This time though set USERI1 to the value you want to start with. (Thanks to MIKE.PERRY the AUGI director). ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Quote
