Overlapping viewports
Hi
In a previous Thread 3 months ago I was told the following to solve my problem. (sorry I do not know how to link to the thread)
"If you are changing VSEDGES to create a new visualstyle, would it be a good idea to create overlapping viewports - whereby one viewport has the visualstyle which contains VSEDGES set to 1 or 2 (to show the edges on steelwork) and the other viewport has the visualstyle which contains VSEDGES set to 0 (to remove the edges for the pipework).
Obviously, if you choose this method, you would have to manage the layers in the separate viewports accordingly."
Could anybody tell how to overlap viewports so you can the information both viewports at the same time. When I overlap vports the top one covers all the information in the bottom one like a wipeout does.
Thanks for any help
I am using AutoCAD 2009 for 3D and also have AutoCAD LT 2008 if I overlap the viewports in that they are clear and I can see both views
So as you say there must be a varible, Is there an easy way of finding the right varible
Thanks
Only seems to be happening when I start a new 3D drawing with a Acadiso3D template. If I open a Acadiso template the vports overlap and I can see both.
  • 1 month later...
I am using 2009 and when i overlap viewports you can see what's in all the VP's.
on the flip side, i actually would like your problem.
I used to be able to hide the objects in overlapping viewport's by just turning the VP layer off and not freezing the layer, but this was in 2007 sadly not in 2009.icon8.gif
anybody know the fix??
It seems to be a problem when the viewports contain 3D drawings then 1 viewport covers the other.
If you do it with 2D drawings both viewports are clear
