Hi
I am using Autocad 2009 with xp pro 32bit. Using ALIGN command in a drawing, when I type in the command and pick the two points of the object to align, the object either scales down or scales up depending on the object I want to align with.
I will be grateful for your help, this is my first time on the forums for help.
Thanks in advance.
Mcad88
You should get an option on the command line to accept or reject scaling.
Thanks for getting back to me, unfortunately the accept or reject scaling cannot be seenn on the command line
This is the command line history when I use Align, using two points
Command: ALIGN
Select objects: 1 found
Select objects:
Specify first source point: ENDP,INT
of
Specify first destination point: ENDP,INT
of
Specify second source point: ENDP,INT
of
Specify second destination point: ENDP,INT
of
Specify third source point or :
Scale objects based on alignment points? [Yes/No] :
If you use three points, you don't get an option for scaling
lpseifert
Thanks for you quick response, must say all the response I had has been great.
I used align then used only one align command, this helped.
Thanks again
Mcad88
