Problem with copyclip
I have problem with autocad? When I tried select any object in drawing with crosshair from left or right side, objects are selected, but in command bar now appears "_copyclip" and these objects are copied to the clipboard. The "_copyclip" also appears in command bar when I select object simply select it by left mouse button, and want to drag this object to other place in drawing by holding left mouse button.
So the question is, why this "_copyclip" activated? This problem appears suddenly, till this everything was normal!
You're saying that copyclip is invoked simply by selecting an object and trying to move it?
In command bar "_copyclip" appears when I move any object to any place in drawing by holding left mouse button and release left button. Then in command bar activated "_copyclip" and offer "select objects".....
I notice, that command "_copyclip" activates also, when I make simply double click in any empty place on drawing. I mean, that I didn't select any objects, just make double click......
P.S. Sorry for my english. I hope that somebody understand my problem :)
When did the problem first occur?
Have there been any updates for Civil 3D 2010 issued? If so, have you installed any?
This problem first appears couple mounth ago on Civil 3d 2009. Precisely I don't remember, but first time it appears when I make my drawing and from "Comunication center" pop up message "To cycle overlapping objects.....press shift+space or ctrl+space (I didn't remember exactly :))". I didn''t read that message completely, and push the combination of these keys. After that, the "_copyclip" activates.
First I reinstall Civil 3d 2009, but that "_copyclip" appears again. Then I tried change some settings in options->user preferences tab and selection tab. I change settins on "Priority for Coordinate Data Entry" and suddenly it stop, but after some weeks, appears again.
Last week in autodesk.com I search solution by searching what means "overlapping" and "cycle", and tried comand "legacyctrlpick" and enter value 1. After that command, everything was normal, but this morning this "_copyclip" activates again.
I'm tryed almoust all settings in options, but somehow that "_copyclip" activates again!
How do you think, this problem bounded with autocad settings or maybe with computer setings. I asked to all my colleagues and friends about this problem, but nobody nows the answer :)
The fact that the problem keeps reappearing after you have corrected it does sound puzzling. Do you use and custom Lisp routines that incorporate the copyclip command?
Oy, I forgot about updates. Yes, I installed updates for civil 3d 2010 sp1 and sp2, because I was a problem with corridor modeling (problem with COGO points from corridor) and I think that updates will help. But these updates I installed last week, but "_copyclip" appears again today.
No, I didn't use any Lisp commands.....
  • 9 months later...
I had the same problem and it was due to an installation of «client for google translate». Just disable that client with right mouse clic on the icon in the task bar !
