absolutsnwbrdr Posted January 21, 2010 Posted January 21, 2010 We are having an interesting issue in my office, and I can't seem to figure it out.... In all of our drawings, we use an block as a plot stamp... in the block, there is one item: an rtext string that contains the following: $(getvar, "dwgprefix") $(getvar, "dwgname") $(edtime, 0, MON DD","YYYY - H:MMam/pm) When we plot or publish, most of our computer will spit out the current file path and date, etc, and everything is great! But on one of our computers, instead of plotting the actual file path, it will plot the temporary file location instead. Has anyone else experienced this? Any idea why this is happening? Quote
absolutsnwbrdr Posted January 21, 2010 Author Posted January 21, 2010 Yeah, my computer will plot it correctly, but the one guy cannot get it to plot right. Quote
mdbdesign Posted January 21, 2010 Posted January 21, 2010 Did you try to edit block on his computer? Quote
absolutsnwbrdr Posted January 21, 2010 Author Posted January 21, 2010 No because the file is on our network, and potentially anyone in our office may need to access/edit it. I don't believe the block to be at fault at all since it works fine on other computers.... i think it must be some system variable causing the fault. Quote
Shtevil Posted January 22, 2010 Posted January 22, 2010 We use a piece of Mtext in our titleblock with the following fields instead of Rtext. File Name %% Layout Name %% File Location %% Plotted by %% Plot date %% It works every time.....set the fieldeval system variable to "31" and the fields will update on open, regen, plot and save. Quote
Denny Posted July 27, 2012 Posted July 27, 2012 This was awesome. I didn't know you could put code in text boxes. Graduated in 96. Somewhat embarrassing. Thank you. works perfect! Quote
