Does anybody have a lisp that will launch a dim set to the current dimstyle but with override text already set. I want one that will read "Existing Road".
Thanks.
Hi Woodman,
Try this:
;; Dimension Reactor  ~  Lee Mac - 21.01.10
(defun c:DimReact nil
 (vl-load-com)
 (if (not (vl-position "DIMOVER"
            (mapcar (function strcase)
              (mapcar (function vlr-data)
                (mapcar (function cadr)
                  (vlr-reactors :vlr-command-reactor))))))
     (vlr-command-reactor "DIMOVER"
       (list
         (cons :vlr-commandEnded 'DimOver)))
     (princ "\n<< Reactor Initiated >>"))
   (princ "\n** Reactor Already Running **"))
 (princ))
(defun DimOver (Reactor Arguments / ent obj)
 (if (and (wcmatch (strcase (car Arguments)) "*DIM*")
          (setq ent (entlast))
          (wcmatch
            (strcase
              (vla-get-ObjectName
                (setq obj (vlax-ename->vla-object ent)))) "*DIMENSION*"))
   (vla-put-TextOverride obj "Existing Road"))
 (princ))
(defun c:DimReactOFF (/ Reac)
 (vl-load-com)
 (if (and (setq Reac
            (car
              (vl-remove-if-not
                (function
                  (lambda (x)
                    (eq "DIMOVER" (strcase (vlr-data x)))))
          (vlr-added-p Reac))
     (vlr-remove Reac)
     (princ "\n<< Reactor Deactivated >>"))
   (princ "\n** Reactor Not Running **"))
 (princ))
Type "DimReact" to switch it on (only need to do this once per session), and "DimReactOff" to switch it off.
Thanks for that LeeMac. Can it be setup as a toggle so that I can toggle it on and off with a button on a ribbon rather than having 2??
Certainly, all the code was there - just needed a small modification :)
(defun c:DimReact (/ Reac)
 (vl-load-com)
 (if (not (and (setq Reac
                 (car
                   (vl-remove-if-not
                     (function
                       (lambda (x)
                         (eq "DIMOVER"
                           (strcase (cond ((vlr-data x)) (""))))))
               (vlr-added-p Reac)))
       (list
     (vlr-remove Reac)
     (princ "\n<< Reactor Deactivated >>")))
 (princ))
          (wcmatch
            (strcase
              (vla-get-ObjectName
 (princ))
LeeMac, I'm getting this error on running it:
Command: dimreact
; error: bad argument type: stringp nil
LeeMac I have looked at this in VLIDE to try to spot the problem. The following shoes up on the error trace:
LOG Error trace
:ERROR-BREAK
[2] (STRCASE nil)
[3] (# #)
[4] (VL-REMOVE-IF-NOT (quote #) (#))
[5] (C:DIMREACT)
:CALLBACK-ENTRY
:ARQ-SUBR-CALLBACK
Was a LISP needed for this? Is it not possible to Right Click (on dim) --> Properties --> and then select Text Overide?
Yeah, but this may is quicker :twisted:
Of course, why didnt I think of that? LOL
Thanks for that LeeMac. Worked a treat..
You're welcome Woodman :)
  • 5 weeks later...
LeeMac,
I have this up and running now in my ribbon but is there a way to set the override text to be on more than one line?
Thanks.
LeeMac,
Thanks.
Yes, use the "\\X" symbol:
 (vl-load-com)
                 (car
                   (vl-remove-if-not
                     (function
                       (lambda (x)
                         (eq "DIMOVER"
       (list
     (vlr-remove Reac)
 (princ))
          (wcmatch
            (strcase
              (vla-get-ObjectName
   (vla-put-TextOverride obj "Existing\\XRoad"))
 (princ))
