David O'Donnell Posted January 21, 2010 Posted January 21, 2010 I am using land Desktop3, survey3, Civil Design3. I'm at a loss to find the tutorial showing how to determine & shade the 20% slopes on a surface. Could someone explain the proccess? Also I imported contour lines, but I can't seem to get them to be a "surface"..any ideas? Quote
BIGAL Posted January 22, 2010 Posted January 22, 2010 1 The shading options are buried away in the styles you can do things like shade the contours not sure about slope though. 2 just bringing in Contour lines could mean just that you have a bunch of lines, you have to create a suface model from your lines, its an option under surface definition autocad objects. Are the lines all at 0.0 elevation ? then your stuffed. Not really its another posted soloution on this forum. Quote
David O'Donnell Posted January 22, 2010 Author Posted January 22, 2010 It was the range settings I was messing up....My only issue now is is there a way to changethe generated shades styles' (ei: change the solid to a cross) ? Quote
David O'Donnell Posted January 22, 2010 Author Posted January 22, 2010 ...my bad, our office never went ahead with the Civil3D, I'm trying to do this in Land developement 3. Quote
David O'Donnell Posted January 22, 2010 Author Posted January 22, 2010 I switched over to Civil 3D, made those changes in that box........and nothing changed. Quote
