melox Posted January 22, 2010 Posted January 22, 2010 Hi, I've watched a David Cohn You Tube Tip on applying and mapping materials to a cylinder. I thought it was very good so I had a go. It didn't turn out out the same. The problem I had was when I tried to map it to the cylinder. The clip has had a few hits now mostly me I guess. I'm left with two straight strips of labels. If any one has the time to have a go at it I'd love to now how to do it. I've tried it in mm & inches but no luck. The dimensions I took for the cylinder was R-74 H-100mm. My actual label was 230mm x 100mm. It was a tin of Heinz Tomato Soup if anyone is interested. I would of have uploaded the label but it was too big a file. Regards Mike. P.S. If you know of a tutorial on this it would great. Googled it with no luck. Quote
