Kobbe Posted January 22, 2010 Posted January 22, 2010 I want to use Gradient fill to a 3D solid but it won't show up, If I test it to a 2D model it works. So, how do I use gradient fill on a 3D solid? Thank you// Kobbe Quote
CADMASTER1128 Posted January 22, 2010 Posted January 22, 2010 I am no expert with 3D models, when you want to apply a texture or color to an object then you want to use "Material Apply / Apply Material." Quote
Cad64 Posted January 22, 2010 Posted January 22, 2010 You can't apply hatch patterns to 3D models. Why do you want a gradient hatch on your model anyway? Can you post an example of what you're trying to do? Quote
Kobbe Posted January 22, 2010 Author Posted January 22, 2010 You can't apply hatch patterns to 3D models.Why do you want a gradient hatch on your model anyway? Can you post an example of what you're trying to do? Ok, that is bad . Are more intressted if it could be done rather than doing something special. Sertain things would look better in two colors. And if I had some hatch pattern I could do for example the floors (use brick pattern) Quote
todouble22 Posted January 22, 2010 Posted January 22, 2010 Ok, that is bad . Are more intressted if it could be done rather than doing something special. Sertain things would look better in two colors. And if I had some hatch pattern I could do for example the floors (use brick pattern) why not do it with materials as stated earlier? Quote
Kobbe Posted January 23, 2010 Author Posted January 23, 2010 why not do it with materials as stated earlier? But is it possblie to make a pattern or something like that? (Have not been testing material so much yet, mabye in a couple of hours.) Quote
SEANT Posted January 23, 2010 Posted January 23, 2010 3D objects can be hatched as long as the face in question is flat (See attachment in this thread). http://www.cadtutor.net/forum/showthread.php?t=44021 The process is a bit laborious as a UCS has to be set for each face orientation. If the object is indeed a 3dSolid then the area for the Hatch/Gradient has to be added via “Pick Point” (may need multiple picks for any given face). I’ve investigated some of the steps needed to hatch* a non-planar face but the routine is not ready for production work. http://www.cadtutor.net/forum/showthread.php?t=41260 *I say hatch but it is actually a hatch exploded to geometry and mapped to the curved surface. Quote
Cad64 Posted January 23, 2010 Posted January 23, 2010 Ok, technically you can apply hatch patterns to a model, but the hatch will not show up when you render. And, as previously stated, it's a very tedious process because the hatch can only be applied to flat surfaces that lie on the current UCS. I would really recommend using materials. You can create tileable textures in Photoshop that can easily be applied to any surface and will show up in your renders. If you can't afford Photoshop, try Gimp. It's a free Photoshop clone. Autocad Materials: http://www.we-r-here.com/cad/tutorials/level_3/3-9.htm http://www.we-r-here.com/cad/tutorials/level_3/3-13.htm http://www.we-r-here.com/cad/tutorials/level_3/3-14.htm Creating tileable textures: http://www.game-artist.net/forums/vbarticles.php?do=article&articleid=15 Quote
Kobbe Posted January 23, 2010 Author Posted January 23, 2010 Thank you all! Going to read a little bit more and see what I can do. Quote
