AutoCAD 2010
I am having problems with the following code that I have written to plot drawings
using existing page setups. The batch routine reads a drawing list in file c:/VBdwgFilelist.txt
to create the batch loop. It uses FitLayoutCanon2870GE11x17 for the page setup
name. The routine stops at the Plot.DisplayPlotPreview acFullPreview
ThisDrawing.Plot.PlotToDevice. Can anyone tell me what I am doing wrong?
I think I need to reset the objects since I am in a loop for different drawings
but I could be wrong. I don't know how to reset objects in vba. Can anyone
help?
thank you,
Private Sub PlotRoutine()
Me.hide
If batchloopcount = 0 Then
Dim lstName As String
Dim PlotConfigurations As AcadPlotConfigurations
Dim Plot As AcadPlot
Dim Activelayout As AcadLayout
End If
Set PlotConfigurations = ThisDrawing.PlotConfigurations
Set Plot = ThisDrawing.Plot
Set Activelayout = ThisDrawing.Activelayout
Activelayout.RefreshPlotDeviceInfo
lstName = "FitLayoutCanon2870GE11x17"
'lstName = "FitLayoutCanon2870GELetter"
'lstName = ComboBox1.Value
If lstName = "" Then lstName = "FitLayoutCanon2870GE11x17"
Activelayout.CopyFrom PlotConfigurations.Item(lstName) 'lstname.value is the user selected Page Setup
ThisDrawing.Regen acAllViewports
'Plot.DisplayPlotPreview acFullPreview
'Me.Show
End Sub
Private Sub CommandButton8_Click()
Me.hide
'On Error GoTo FileError
Dim TheDrawingname As String
AutoCAD.Documents.Close
batchloopcount = 0
Open "c:/VBdwgFilelist.txt" For Input As #6 ' Open file for input.
Do While Not EOF(6) ' Loop until end of file.
Input #6, TheDrawingname ' Read data into two variables.
'Debug.Print MyString ' Print data to Debug window.
'If TheDrawingname "" Then ThisDrawing.Open (TheDrawingname)
AutoCAD.Documents.Open (TheDrawingname)
'MsgBox ("Plot Prompt")
PlotRoutine ' For plotting above
batchloopcount = batchloopcount + 1
ThisDrawing.Save 'Save the drawing
ThisDrawing.Close
End If
Loop
Close #6 ' Close file.
Me.Show
Exit Sub
FileError:
Close #6
MsgBox "File Error"
'progerror 'program error
'Resume Next
End Sub
For anyone interested. Here is my corrected Batch Plot Routine:
Private Sub BatchPlotRoutine()
Me.hide
End If
Plot.PlotToDevice
'ThisDrawing.Plot.PlotToDevice
'Me.Show
End Sub
Me.hide
Dim BackPlot As Variant
BackPlot = ThisDrawing.GetVariable("BACKGROUNDPLOT")
ThisDrawing.SetVariable "BACKGROUNDPLOT", 0
batchloopcount = 0
BatchPlotRoutine ' For plotting above
ThisDrawing.SetVariable "BACKGROUNDPLOT", BackPlot
ThisDrawing.Close
End If
Loop
Me.Show
Exit Sub
FileError:
Close #6
MsgBox "File Error"
'Resume Next
End Sub
Could you plz upload the DVB file or dwg embaded with this DVB?
