veranco Posted January 27, 2010 Posted January 27, 2010 Hi everyone I'm trying to implement a function with VBA that prints both a pdf (PDFCreator) and then prints to the selected printer. I managed to make the function but I still have three problems: 1st This function should replace the standard print function of autocad, and I cannot seem to find a solution for that. 2nd It works terribly slow (around 120s per layout) 3rd I get two errors (one for each printer) from Windows: 'AutoCAD Application stopped working, ...', the typical windows error. This is a problem, but it is least important because Acad keeps working. Please help. Forgot to mention: AutoCAD 2007 on Windows Vista SP2 32-bit Quote
veranco Posted February 9, 2010 Author Posted February 9, 2010 This is the code I have, maybe that might help someone to help me? Option Explicit Declare Sub Sleep Lib "Kernel32" (ByVal dwMilliseconds As Long) Public Sub PlotPDF() Dim Plotter As String 'Plotter = "\\printserver\HP LaserJet 2420 - Groep 2 (Lade 2)" Plotter = ThisDrawing.ActiveLayout.ConfigName Dim Layout As AcadLayout Set Layout = Nothing On Error GoTo Err_Control Set Layout = ThisDrawing.ActiveLayout Layout.ConfigName = Plotter ' CALL PLOTTER Layout.PlotType = acLayout Layout.PlotWithPlotStyles = True Layout.PlotViewportBorders = False Layout.PlotViewportsFirst = True Layout.PaperUnits = acMillimeters Layout.ShowPlotStyles = False Dim pdfjob As PDFCreator.clsPDFCreator Dim sPDFPath As String Dim sPDFName As String sPDFPath = ThisDrawing.Path + "\pdf\acad" sPDFName = ThisDrawing.ActiveLayout.Name ThisDrawing.Plot.NumberOfCopies = 1 Set pdfjob = New PDFCreator.clsPDFCreator With pdfjob If .cStart("/NoProcessingAtStartup") = False Then MsgBox "Can't initialize PDFCreator.", vbCritical + _ vbOKOnly, "PrtPDFCreator" Exit Sub End If .cOption("UseAutosave") = 1 .cOption("UseAutosaveDirectory") = 1 .cOption("AutosaveDirectory") = sPDFPath .cOption("AutosaveFilename") = sPDFName .cOption("AutosaveFormat") = 0 ' 0 = PDF .cClearCache End With 'Print the document to PDF ThisDrawing.Plot.PlotToDevice ("PDFCreator") 'Wait until the print job has entered the print queue Do Until pdfjob.cCountOfPrintjobs = 1 DoEvents Loop pdfjob.cPrinterStop = False 'Wait until PDF creator is finished then release the objects Do Until pdfjob.cCountOfPrintjobs = 0 DoEvents Loop pdfjob.cClose Set pdfjob = Nothing Sleep (20000) ' Waits for 20 seconds ThisDrawing.Plot.PlotToDevice ThisDrawing.Regen acAllViewports Set Layout = Nothing ThisDrawing.Save Exit_Here: Exit Sub Err_Control: Select Case Err.Number Case "-2145320861" MsgBox "Unable to Save Drawing- " & Err.Description Case "-2145386493" MsgBox "Drawing is setup for Named Plot Styles." & (Chr(13)) & (Chr(13)) & "Run CONVERTPSTYLES command", vbCritical, "Change Plot Style" Case Else MsgBox "Unknown Error " & Err.Number End Select End Sub Quote
