chiamulera88 Posted January 27, 2010 Posted January 27, 2010 Hi!! I'm a beginner AutoCad Plant 3D 2010 user, and I've got some doubts adding configurations for joints and pipes. Can I creat diferents flanges with diferent joint configuration in a same project? I've already got the configuration for each flange/joint, but when I try to use them, the P3D apllies a default configuration for all flanges, I mean it apllies the same configuration for diferent kind of flanges. In my case: I got a open project where I need to implement: welded neck flange, slip on flange and lap joint flange. Even got a diferent joint configuration for each flanche, I can only implement the configuration for welded neck flange, even using slip on or lap on flanges. Which menu should I acess to change this configurations, or what Cad properties should I change?! Thanks in advance!! Quote
