Is there any way to chance the default page to open when you start ACAD, or better yet disable it? Thanks :)
What do you mean by default page?
If you mean the Startup page...
from Help for Startup
Type: Integer Saved in: Registry Initial value: 0
Controls whether the Create New Drawing dialog box is displayed when a new drawing is started with NEW or QNEW. Also controls whether the Startup dialog box is displayed when the application is started.
If the FILEDIA system variable is set to 0, no dialog boxes are displayed, except for the Customize User Interface dialog box.
0
Displays the Select Template dialog box, or uses a default drawing template file set in the Options dialog box, on the Files tab.
1
Displays the Startup and the Create New Drawing dialog boxes
