concreteinterface Posted August 14, 2008 Posted August 14, 2008 I'm an amateur AutoCAD 2007 user... I am by no means an expert... I would like a way to select say 5 different layers and turn them off with a hotkey... Any suggestions? Thanks, Ryan Quote
Tiger Posted August 14, 2008 Posted August 14, 2008 the command LAYFRZ turns off layers as you click on a object on that layer, would that be enough? If they are always the same layers, the same laayer names then I suspect a macro could be written, I'm not good at macros though For more complex combinations of Off and/or Freezed layers check out the Layer States feature in the Layer manager, these can be saved and loaded between drawings as well if I remember corectly. Quote
