How do I insert a title block?
How do I insert a title block into my drawing?
Are you wanting to do this in Model or Paperspace?
i dont know??? haha I just want to add a title block to my drawing for printing. I am not sure the normal way to do it...
HAHA, OK next question is what type of drawing is this? Mechanical, Architectural, Civil, etc.
architectural, im hoping there is some basic title block that i can just add and change or add my name etc to it.
oh and maybe a nice little North arrow :)
I am attaching a PDF here with Title Block styles and sizes.
I normally use form 5 for my Architectural Drawings. Don't draw the title blocks to the size given. What you need to do is draw them to scale.
Example: Form 5's length is 4.50''. A normal architectural is at 1/4'' Scale.... so divide .25 by 4.50... (.25/4.50=18) So you will actually draw the 4.50'' line at a length of 18''.
Make sense?
Your North Arrow can be found in you DC, Design Center. If you are unable to find let me know and I can attach one.
Title Block-1[2].pdf
There are basic templates provided with AutoCAD. Use the following steps to bring one into your drawing:
From the drop down lists at the top:
Insert>Layout>Layout from Template - then browse to: C:\Program Files\AutoCAD LT 2005*\UserDataCache\Template
*Shows your AutoCAD folder
Over the years, I've had different titleblocks. Just for change's sake.
I did start with AutoCAD templates, don't know where I got the one I've attached.
I print only letter size or *.pdf format (for emailing). 8)
Titleblock-Generic.dwg
  • 1 year later...
Don't you just hate it when the OP never comes back to reply, or say Thanks ?.
that's what i thought when i saw this post.
at least inunuo above registered here just to say "thanks"!
