Dimension fill color off
Hi,
I'm using 2010 and my dimensions text is creating a background mask, I have tried selecting 'none', I have tried 'TEXTFILL' and DIMTFILL- but nothing seems to work.
Can't find anything else on any other forums that describe this problem.
Has anyone got any suggestions?
TEXTFILL here not and,
DIMTFILL-> 1, should help, but only for again created
As look at the dimension at property panels, in section the Text, colour of filling. What there?
Or show a file where a problem
Dimtfillclr doesn't work
textfill dosen't work
dimtfill doesn't work
What else do you have?
Dorian Gray , Well, show us the file where at you a problem and then we can precisely tell (probably even I will show) what and how it is necessary to make.
so no response means you can't fix the problem?
It works fine here, I use background or none for color and it goes away.
What color do you use for your screen background? I use black and don't see a problem. I switched to white and had to force a regen, no longer showing there as well.
it is certainly happening over here and its quite frustrating, does anyone else have a possible solution????:cry:
I just opened the Dimension Style Manager, set the Fill color to None and problem solved. I'm not sure why it doesn't work for you though.
  • 7 months later...
Im having the same problem. I have a Dim style that has the Background fill colour. I've gone in the style manager to change it to none, but each time I close/re-open the drawing it comes back!! I could simply create a new style and change all of the dims, but I want to find out why this is happening. If one of your knows the answer that would be great.
