nulan Posted January 29, 2010 Posted January 29, 2010 Regards to all! How can I create a region (need to extrude) from a lines that are not complanar? I need it to calculate mass Quote
JD Mather Posted January 29, 2010 Posted January 29, 2010 Loft and Thicken might be your tickets. Can you attach the file here? Quote
nulan Posted January 29, 2010 Author Posted January 29, 2010 Loft and Thicken might be your tickets. Can you attach the file here? Offcorse Just to explain. This is original measurement of my terrain with height measured by official geodesist. My plan is to create 3d hill, so I can insert position of house (3d) and measure cubic meters that must be removed (dig up). ground.dwg Quote
JD Mather Posted January 29, 2010 Posted January 29, 2010 Might need to clean up your polylines a bit. Loft surface and then Split the ground with the Surface option. There is an example in the tutorials in my signature. Quote
nulan Posted January 31, 2010 Author Posted January 31, 2010 Might need to clean up your polylines a bit. Loft surface and then Split the ground with the Surface option. There is an example in the tutorials in my signature. I know that I need to create few regions to extrude them separately, so can you please help me to create region from this. ground1.dwg Quote
scj Posted February 1, 2010 Posted February 1, 2010 Hi nulan, I made regions out of your contour lines (It is a secondary effects from making unfoldings by the ANTARES-programs). Good luck Jochen ground1-1.dwg Quote
